Old 04-18-2004, 04:54 PM   #1
krue
Designated A-hole!
krue's Avatar
Unhappy What did I tear up?
I am getting a knocking sound from my tranny (th350) when I put it into gear, drive or reverse. No noise in neutral or park, and it goes away when I give it gas. Any help?
Thanks, Krue
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-18-2004, 05:23 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
When my flexplate cracked, it knocked all the time. Maybe yours is cracked, but in a different way?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-18-2004, 05:47 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Had the same problem sounded like a light rod knock and it turn out to be the flex plate..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-18-2004, 06:02 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Had one with a loose converter, made a butt load of noise(knocking) at idle and steady cruise, fairly quiet when i had my foot in it.
Old 04-18-2004, 06:20 PM   #5
krue
Designated A-hole!
krue's Avatar
I need a new flexplate anyways, the teeth on mine are worn pretty bad. Hopefully that's all it is.
www.daveramsey.com
Old 04-18-2004, 06:28 PM   #6
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Does it clunk all the time or just when you put it in and out of gear? If it only does it goin inb and out of gear(shifting into the gears using the shifter, not changing gears driving it) it most likely is a u joint or possibly a mount. If it clunks or knoscks all the time no matter what the trans is doing, it may be a cracked flywheel like everyone else says, or loose flywheel bolts, something that got up into the cnvertor housing or possibly the start pnion not going back into the starter far enough and the teeth are hitting it.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 04-18-2004, 10:42 PM   #7
On the 82, had the same sounding noise and turned out to be U joints...both wereshot to heck.
