Old 04-18-2004, 05:57 PM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
lifting 2wd trucks
how do you lift a 2wd and how much can you lift one?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 04-18-2004, 07:19 PM   #2
71chevylongbed
Got Horsepower?
ttt
Old 04-18-2004, 07:32 PM   #3
walker
walker's Avatar
Easiest way is with new springs. This might not be a common truck to do it on, so your options may be limited. Check with your local 4x4 shop. You may have to go to a spring shop and have some made, not too expensive. Best way would be with springs in the rear and spindles in the front, as I said you will have to find out about availability for this model. You may end up using lift spindles from a later model and adapting your tie rods etc. Need to be careful with the spring lift as it plays heck with your front end alignability, and may put you out of specs for camber. Hope this helps you out some, I did it on a 94 with springs, made the ride stiff as hell.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 04-18-2004, 08:51 PM   #4
bagged78
world class smart ass!
bagged78's Avatar
http://67-72chevytrucks.com/vboard/s...hreadid=100058
Read this
Aric
75 2WD BLAZER (never ending project)
-some day maybe-
02 2500HD CREW CAB 4X (daily drive)
-8" lift 37s and 22s-
____ ____________________________
bagged78 is offline   Reply With Quote
Old 04-19-2004, 12:24 AM   #5
71chevylongbed
Got Horsepower?
thanks for the info. i think that i'll keep this truck how it is and save up some more $$$ and buy a nice 67-72 4x4
