Old 04-18-2004, 07:09 PM   #1
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
What manual trans will replace the three speed?
Will a Muncie, saginaw, or Super T 10 bolt in the same as the factory three speed in a 72? The trans looks similar to the 3 speed that was in my 66 Malibu but not sure. Are the lengths the same as a three speed? I know I will have to use a floor shifter but am more concerned with actual trans swapping. Is the input shaft bearing retainer the same diameter as the car four speeds where it fits into the bellhousing? Any help will be appreciated.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 04-19-2004, 02:22 AM   #2
72C203503ONTHETREE
I may be getting a NV4500, but what style trans will work as a bolt in if I blow my three speed up until I get the 4500 installed?
Old 04-19-2004, 08:03 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dude, if memory is correct, a Saginaw 4 speed is a straight in swap, with a floor shifter as you mentioned, of course.
