PROJECT 7DEUCE
![]() Join Date: Dec 2002
I just installed some l.e.d. front turn signal's behind the grill on my blazer and am having a problem with the light's staying on with the headlight's... How can I rememdy this problem it really is bugging me.. B.T.W the l.e.d.'s are just little trailer light's... Also I do have the electronic flasher too.. Any help would be great...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
How did you connect them?
72 Cheyenne Super 4x4 SWB |
its all about the +6 inches
Just making sure I'm reading this right, the parking lights turn off when the head lights tun on, right? And it did not do this before?
A 67 would do that, but I can't see why a 72 would, you checked your grounds already? |
PROJECT 7DEUCE
The l.ed. 's are on when the light switch is on... I t don't matter if I have it set on parking light's or headlight's.... I would like the led to come on only when I use a turn signal and I double checked the ground's.... Thanks's guy's...
FRENCHBLUE72,
Are your LED's set up to run at two different intensities, either through a resistor/diode set-up or turning some of the LED's off for the dim/park light function? I guess the easiest way is to count the number of wires/hook-up points are on the assembly. Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
You want to disable the parking light, and only have directionals...
Cut the brown wire. |
PROJECT 7DEUCE
Yep long horn that's what I would like to do... I will give that a shot after work and let ya guy's know what happen's..
PROJECT 7DEUCE
All I have hooked up is the yellow wire and I still get light???
FRENCHBLUE72,
Can you provide a litttle more detail about how you hooked up the lights originally? What color wire from the new LED's is spliced to what color wire in the original harness? Also, a little more detail on the "electronic flasher" as I have had to try a couple of different ones on my F-100 LED taillights, before I found one that worked. Good Luck!
PROJECT 7DEUCE
O.k. the flasher is a TRIDON ELECTROINIC FLASHER 12 VOLT
PROJECT 7DEUCE
YELLOW GOES INTO THE BLUE AND THE BROWN IS NOT HOOKED UP .. THE LED HAD IT'S OWN GROUND...
THIS WIRING WILL BE HEAT SHRINKED AND CORRECT WHEN IT'S DONE
PROJECT 7DEUCE
HERE'S A PIC OF THE LIGHT..
FATFORD'S IF YA NEED SOME MORE INFO PLEASE LET ME KNOW..
