Old 04-18-2004, 09:27 PM   #1
bumpster
Junior Member
Need Ford help
I know this is not an off brand forum, but I am at wit's end. 85 F*@# half ton, in-line 6, put old style carb on about 3 yrs ago to eliminate the last of the smog stuff. EGR is capped off and lines are plugged. All was well till suddenly it started to run way too rich, won,t idle, blows black smoke. If I take the brake booster vacum hose off, engine speeds way up and smooths out. Why does this seem backwards to logic, and what am I not finding?
Any ideas other than the obvious{burn it}, would be much appreciated. Thanks in advance.
72 C10 10 yr.daily driver
68 C10 18 yr.money pit
72 Nova all original
99 H.D. Heritage[sanity check]
71 VW topless bug[summer fun]
"When I have the money, I don't have the time ; when I have the time, I don't have the money.
bumpster is offline   Reply With Quote
Old 04-18-2004, 09:59 PM   #2
Eddie H.
Eddie H.'s Avatar
It sounds like you need the carb rebuilt. The needle valve in the inlet may not be sealing properly and allowing the carb to flood the engine with fuel. By removing the brake booster hose, you're creating a big vacuum leak and leaning out the fuel mixture is the reason it runs better that way.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 04-18-2004, 11:32 PM   #3
krazy_texan
krazy_texan's Avatar
best fix is to drive it off a cliff, lol
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 04-19-2004, 08:11 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
gospel...listen to the man.
Old 04-19-2004, 10:46 PM   #5
bumpster
Junior Member
O.K., I took the advice to heart, replaced carb. with a rebuilt holley unit. GOOD CALL, truck now idles smooth{for a f$#d}, and is back to it's primary duty of taking my 90 yr old dad to fishing holes. Thanks guy's.
