This, is my BOOMSTICK!
Engine cleaning question
I just bought another 67 and the motor has a layer of grease and dirt on it about 1/2 inch thick. What is the best way to get this all off? what is a good solvent that will help loosen up this stuff?
Thanks in advance, Larry.
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) |
"Gunk" engine brite cleaner and a bristle brush. If it's 1/2" thick you should probabably scrape off what you can before you start washing it. Spray gunk on there let it sit a few and brush it, repeat as neccesary, and then just rinse it clean with the garden hose.
72 Cheyenne Super 4x4 SWB |
I personally love some stuff called super cleaner. I think that is what its called. It comes in a purple bottle. If you dont dilute it, which works best, spray off quickly, or else it will strip paint. my engine brakets are now orange again after thinking longer is better. brakets were painted red.
~Christopher L. Orr 71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc. |
Well, one nice thing about gunk is it's very effective against grease, but won't damage paint, hoses or wires. It also rinses very easy and leaves no residue. Gunk will only disolve the grease, it will not clean regular dirt or whatever else.
Thanks guys,
That's the problem though, the motor is still in the truck with everything else. So it's going to have to be a cleaner that isn't going to ruin the wires hoses and everything else in there. It sounds like the Gunk engine cleaner is a pretty good option. Faster_than_you, I think that the stuff that you are talking about is Castrol super clean. I heard that that stuff works great but I think that it may be too strong. I guess it could be diluted though. Thanks again, Larry
I've seen Super clean fade paint before. I've used oven cleaner with good success.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
Easy Off Oven cleaner works good. In the old days I used to wet the engine down and dump Tide laundry detergent on it and pressure wash it off.
Scott
1969 GMC 3/4 Ton Long Bed Fleetside 350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb Beaverton / Portland Oregon |
You could let it run at opt. temp while cleaning it! This will help against damage!
gunk, castrol S C , Tide, Oven easy off, all work good! Once it is clean put Armoral all over and let it sit over night! What a shine in the morning! Cheers ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Wiseass secured himself a BAN
Castrol super clean is the best when it comes to engine cleaner. You may have dilute it some, but it also works great diluted. Don't worry about the wires drying out. Super clean is in a purple plastic bottle so it will not hurt the plastic coating on the wires. I don't use anything else. Go to the car wash and use the pressure washer.
Navel Inspector
Wow! Learning some on this one. I will be doing this myself someday soon but will wait until I make it to the carwash. Give the old truck a bath.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
![]() Join Date: Aug 2001
![]() IT DOESN'T HURT A THING TO POP YOU'RE HOOD & WASH YOU'RE MOTOR OFF EVERY TIME YOU GO TO THE CAR WASH. IF YOU STILL HAVE THE POINTS TYPE DISTRIBUTOR YOU HAVE TO BE A LITTLE CAREFUL ABOUT SPRAYING DIRECTLY ON IT, BUT IF YOU HAVE SWITCHED TO AN HEI, YOU DON'T HAVE TO WORRY ABOUT IT GETTING WET AT ALL. JUST LEAVE THE MOTOR RUNNING WHILE YOU WASH IT, & IT'LL BE DRY BY THE TIME YOU GET 4 OR 5 MILES DOWN THE ROAD. ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
its all about the +6 inches
If you can get access to a steam cleaner, that will do better than anything described here.
With out steam, I'd go for the Super Clean and pressure washer (coin op car wash) The super Clean you get at the parts store is so diluted that it won't hurn anything if you spray it off within a min or two. The industial stuff will do some damage though. Oh, and don't spill the stuff down your "front side"...a co-worker will attest to that. ![]() |
#13 |
I have used all the engine degreaser products you can think of, and the best by far is Easy Off Oven Cleaner!!
Really! Just scrape off the big clumps with a screwdriver, and spray the stuff on, wait 15 mins. and spray it off with a regular garden hose / sprayer. Works great!! Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
#14 |
I did mine with OVEN CLEANER!!!!! Tried Super Clean but got much better results with the oven cleaner.
Alex 1971 Lil' Red 350 SBC 700R4 |
