Old 04-19-2004, 12:23 PM   #1
beeroh
why so hard to shift into gear with np205
my friend has a 79 K10 and he has the np205. Why is it so difficult for his tc to shift into any gear? Im 275lbs and I work out and I have one hell of a time trying to force his gears into 4L and 4H. What is going on with that?
84 Silverado,
beeroh is offline   Reply With Quote
Old 04-19-2004, 12:39 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Does it have any fluid in it? The shifter may need adjusting.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-19-2004, 03:59 PM   #3
beeroh
how would I adjust the shifter
84 Silverado,
Old 04-19-2004, 06:49 PM   #4
1969 GMC
1969 GMC's Avatar
i dont know how you would adjust the shifter, maybe the bushing on the shift arm has gone bad.
also, have you tried double clutching to get it into 4x? I used to have to do that sometimes with my old Rockwell tcase. or, move the truck forward about a foot to take the tension off the gears.
hth
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-19-2004, 07:21 PM   #5
K5KRAZIE
You have to be rolling about 3-5 mph, sometimes you will have to go from reverse to drive (if auto) pop it into neutral and try the t-case again. If you just try to push the lever you will break the shift fork. The gears will get in a bind when doing different things, so you have to get them to unbind.
TRUCKS
'72 K5
'06 mega dually
K5KRAZIE is offline   Reply With Quote
Old 04-22-2004, 02:22 AM   #6
kwmech
Manual trans -- step on the clutch. Auto -- try neutral.
