![]() Join Date: Feb 2001
Heater Hoses?
Are our hoses 3/4? I'm thinking they are but don't have a truck here to look at. Getting ready to order some stuff and need to know....Thanks
Whats radiator hose size while I'm at it? Thanks again! ![]() |
There are two size hoses, 5/8" (goes from lower heater core to intake), 3/4" (goes from upper heater core to water pump). Some trucks have the upper hose going to the radiator.
Jim |
I'm dealing with this today also, Radiator guy wants to know if I need the radiator that has the fitting on the radiator for it to return there. The old radiator is gone, the motor is out so which way to I go??? there is a place on the intake for it to go there and the spot on the water pump so which is it?
Any help would be appreciated..
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. ![]() Last edited by lewi; 04-20-2004 at 07:34 PM. |
If you have an automatic V-8 then I believe the factory setup was back to the radiator. My radiator guy told me that it should hook to the radiator if you have AC.
Jim |
