Motor Swap
Will a 6 auto set up out of a 70 fit these years of trucks?If not what would be a straight swap?
Need more info. What year truck do you have? With what engine and tranny. What engine and tranny does the 70 have?
Larry 68 C20 327 daily driver 63 C20 292 Camper truck 65 C10 ? Custom Cab AC,PB,PS,$flasher |
The 70 has a 250? 3 speed Auto.Runs good but body is poor.Not sure what year the other truck is as I have not bought it yet.Just wanted to know what I was in for as I don,t have any exoerience with these years of truck.
The 63-66 trucks used the 250. Most of the trucks had manual trannys in them, so you will have to consider transmission linkage and probably drive shaft. The exception would be a 292 six which has it's motor mount tower in a different location. You could even use a V8, then you will have to reroute the engine wiring harness. Hope this helps.
