Old 04-19-2004, 05:07 PM   #1
gerry giordano
gerry giordano's Avatar
Back up lights in "N"
When I put my truck in "D" the indicator is actually lined up between "N" & "D." I also don't get back up lights untill neutral which shows between "R" & "N". Anyone out there have a prescribed fix for that?
Thanks.
'69 C-10 LWB, 350, TH350, posi-traction
gerry giordano is offline   Reply With Quote
Old 04-19-2004, 05:23 PM   #2
cdowns
cdowns's Avatar
loosen up the steering column mounts under the dash and on the firewall and rotate the steering column till the pointer is in the right place
Old 04-20-2004, 12:06 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or look for the slop in the shifter rods. If you look where the rod goes to the linkage on the bottom, you may find the hole to be egg shaped, and then the lever on the tranny its self may have worn fingers.
Old 04-20-2004, 02:03 AM   #4
68Custom
Hammer On!
68Custom's Avatar
I seem to have this slop in my shifter as well.... any known fixes to this problem? Is this something to be concerned about?
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
