04-19-2004, 06:01 PM | #1 |
axles
i wanted to swap some 5 stud 71 axles into my 68 6 stud rear end but it seems they are a bit longer. has any one done this and what does it require I dont relly want to change the whole rearend and not relly wanting to splurge 250.00 for aftermarket axles. whats the cheapest solution.
04-19-2004, 07:45 PM | #2 |
...not much choice there almost gotta run the 71 rearend or redrill your axels...but be carefull redrilling them because i was going to redrill my 6 bolt axels to 5 on 4 3/4 so i could use the narrower rear but the center hub is 3 1/2" across and my wheels only have a 3" hole which is what the 5 bolt hubs are so i redrilled the 5 bolts.........
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
04-19-2004, 08:34 PM | #3 | |
I've had them re-drilled & I've upgraded to replacement axles. Both ways work but remember these trucks often have many, many miles on them. If you spend the $$ to re-drill some old axles..... they'll still be old axles. If your making more HP/TQ than factory original, do yourself a favor & upgrade to new, better, aftermarket axles. If it's just a 6-banger/glide..... sure, re-drill 'em.
04-19-2004, 11:57 PM | #4 |
its all about the +6 inches
Some ppl have made spacers to take up the extra room, but I don't have the details on that.
Anyone? |
04-20-2004, 12:26 AM | #5 |
Has anyone ever considered getting axles cut down and resplined.
They do that alot when they narrow them im told they can even cut the notch for a c clip I met phil66 and he had done the spacers on his 70 ? i think it was Not sure what he said he made them out of it but it looked clean. |
04-20-2004, 12:40 AM | #6 |
KEEP ON TRUCKING
i thought i seen the spacers on a vendors web site i think it was ricks not sure though
72 cheyenne 2wd lwb 71 k20 sons bassett va |
04-21-2004, 12:10 AM | #7 |
Actually, i was refering to spacer as a piece os metal to move the whole backing plate 3/8 inch out on both sides...not wheel lug adapters.
04-21-2004, 12:14 AM | #8 |
Thats what i was reffering too as well. Spacers to set the drums out.
