Old 04-19-2004, 08:17 PM   #1
'71c204x4454
'71k204x4454
Easy remove tailgate
This has probably been on here but I just figured it out. The right side hing on a '73 to '81 (I belive those or the years to use) will bolt right up. So then all you would have to do is trim the metal a little on the bottom of your tailgate on the right side and your gate will pull right off at a 45' angle.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 04-19-2004, 10:36 PM   #2
superfly68
superfly68's Avatar
let's see some pics and a how too on this! i'd be interested in doing this!
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 04-19-2004, 10:46 PM   #3
Blue_71
Bloo
Blue_71's Avatar
its not hard to do, i did it on mine. i used a hinge from a 78, but they are the same from 73-87. the hinges are not the same height, so i had to put in the top bolt only, and tighten it really tight. then i took an air cut off wheel, cut 2 slits from outside to very bottem of the trunion hole, then cut across, keep trying the gate on the truck, grinding out metal as needed, untill it slips on easy.
i also did this when i put a 76 ford tailgate on an 85 ford
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 04-19-2004, 11:44 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
How often do you remove your gate?
Personally, i prefer the set up where tools are needed and it is not a quick release...I knew some kids in high school that would grab tail gates off newer trucks and sell them...pure profit.
Old 04-20-2004, 10:07 AM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Then theres the trick of putting a hose clamp over the hinge so at least the thief has to carry a screwdriver with him to steal your gate.
sneakysnake is offline   Reply With Quote
Old 04-21-2004, 12:55 AM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I did this too. Mine is done using the stock 72 trunion with slight modification...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-21-2004, 12:56 AM   #7
72 CustomCamper
huh ???
Tailgate modification...
