Old 04-20-2004, 12:13 AM   #1
Joey-D
City's Articulation Ramp
Joey-D's Avatar
I need a new Steering Stabilizer...
I have 8" lift and 38.5x15 on a 10 bolt with a worn out factory single steering stabilizer and Im a wonderer. Now should I replace it a heavy duty single for $35 or replace it with a dual for $90?
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 04-20-2004, 03:47 AM   #2
Mudder
Mudder's Avatar
Dual.......
Mudder is offline   Reply With Quote
Old 04-20-2004, 11:17 AM   #3
ryanroo
ryanroo's Avatar
ive always heard that if you need more than the stock stabilizer for anything other than looks you need to fix the problem in the steering. but who the hell knows, with tires that big id say dual is fine, plus its probably cheaper than goin through a steering system that is just fine
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-22-2004, 07:33 PM   #4
IoWnZa
Big Block Blazer
Any Tires larger then 35" You want to run a Dual Setup.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 04-22-2004, 10:05 PM   #5
smokkey1
Land Beast
I'm running an single rs5000 stablizer with 36" swampers and it feels real good but I also have an steering box brace
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
