Old 04-20-2004, 03:18 PM   #1
72-396
Unhappy Front tires ?
I have a 72 c20 4x4 and I have noticed that the front tires stick out 2" further on each side than the rear. Is this normal for this rear truck and how do I correct it. Dana 44 and Eaton ho72. Can someone help me out, I would really appreciate it. Thanks
1972 K20 custom camper 4x4 LWB 396 700r4
1965 chevy II 420 hp s/b 4 speed
72-396 is offline   Reply With Quote
Old 04-20-2004, 04:01 PM   #2
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
Its normal. My 72 SWB 4x4 does the same thing. I think it has to do with the steering...needed a little more clearance to turn the wheels.
Bobalouie is offline   Reply With Quote
Old 04-20-2004, 04:25 PM   #3
72-396
Thank you
Old 04-20-2004, 08:01 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It also helps with the tracking of the tires in a turn.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-20-2004, 10:24 PM   #5
72-396
I appreciate your feed back
Old 04-21-2004, 11:46 AM   #6
toddol1971
I know you can put spacers in there. They put a longer axle in the superburb. A 14 bolt out of a van is 3" longer. I wish i could get 3" that easy.
toddol1971 is offline   Reply With Quote
Old 04-21-2004, 12:31 PM   #7
72-396
are you saying spacers in the rear so the front and back will match.
Old 04-21-2004, 03:07 PM   #8
The Dude
ya i think that is what he is saying.
The Dude is offline   Reply With Quote
Old 04-21-2004, 03:16 PM   #9
The Dude
or you could run two sets of wheels with different backspacings, but then you wont be able to rotate the tires front to back, only left to right.
Old 04-22-2004, 07:32 PM   #10
IoWnZa
Big Block Blazer
Yes, they make Aluminum Spacers ($150/each) to put on each rear wheel, I have them on my Blazer. It makes it so that all 4 wheels are the same Legth out of the Fenders.
It always bugged me how the Front Stuck out further then the Rear. Expensive but best way to fix the problem.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 04-22-2004, 11:00 PM   #11
72-396
Ok, that is what I am going to do. I called my dad out in Ca, and he said he can make them for me at his machine shop. I would rather have the same size rims 0n all fours so spacers will be really good.
Old 04-22-2004, 11:36 PM   #12
Destructo
on 73-87s the rear axle is 3" shorter than front, so 1.5" spacers should make it even.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 04-22-2004, 11:43 PM   #13
72-396
Does any body make flared fender pieces for 72 4x4's that would look good. If all four tires are out than I will have rocks and mud hitting the body.
Old 04-23-2004, 01:28 AM   #14
IoWnZa
Big Block Blazer
I don't think I have ever hear or seen "Fender Flare" and "Look Good" in the same sentence!
