04-21-2004, 01:48 AM | #1 |
To Posi or To Lock?
Hi,
I am at a cross between Posi or Locker. I am not a hardcore 8foot RockCrawler just a weekend warrior that likes to go play in mud when I can find it or go on bumpy trails with inclines and declines of about 45 to 60 degrees up or down. What would you recommend, Posi or Locker?
84 Silverado, |
04-21-2004, 02:51 AM | #2 |
it sounds like you would only need a posi...but then again, if you were to buy either brand new, you will find the prices for both equally disgusting.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
04-21-2004, 03:34 AM | #3 |
I heard air lockers were in the mid G's and posi I could find below that.
84 Silverado, |
04-21-2004, 05:51 AM | #4 |
user # 2756
Get a tight posi, such as a powr-loc from dana. What rear axle do you have, this could determine what you get.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
04-21-2004, 11:24 AM | #5 |
the rear has a gm 12bolt, the front a 10. I was thinking about getting posi up front because thats where all the weight is. Am I wrong to think this way?
84 Silverado, |
04-21-2004, 09:32 PM | #6 |
someone at work today mentioned a spool, is that a different kind of locker? They said they were like 200$, and it sounded like a locker limited slip.
84 Silverado, |
04-21-2004, 09:48 PM | #7 |
user # 2756
For the street you would not want a spool. It basically locks the two axles together and both rear tires turn at the same speed all the time, even in a turn and something has to give as the outside tire wants to turn faster than the inside tire. So either a tire chirps or something brakes!
I have a neighbor who runs a trac-loc by dana in the front of his dana 44 and a detroit in the rear. He likes it. The trac-loc is a limited slip and the detroit is a locker.
04-21-2004, 11:41 PM | #8 |
I runn detroit lockers in the front and rear and I love them both.
Earl 68 2500 4x4 GMC Burb |
04-22-2004, 01:43 AM | #9 |
i have a detroit locker in a HO52 that i'm going to run when i get my truck back together, and I want a posi of some sort in the dana 60...new power locks are too expensive, so i will probably have to buy a used dana 60 powerlock (30 spline) and use side gears from a dana 70 power lock (35 spline). there were a couple of guys over at pirate4x4 who have done this.
04-22-2004, 02:32 AM | #10 |
i wouldnt even consider dumping money into that 12 bolt if you really need a traction device. buy a 14FF, and put a detroit in it.
