04-21-2004, 06:53 PM | #1 |
header ?'s
What headers do you guys run for a standard truck?
It's a C-30. thanks Matthew |
04-21-2004, 07:55 PM | #2 |
Fabricate till you "puke"
I have run both Hooker & Headman's on the trucks, with no complaints. The Hooker comps on my Longhorn are a nice fit, & heavier 16 guage tubing than most other brands. a lot has to do with budjet,ect& also be sure to get a set verified for a stick trans if you are running one. Most auto trans apps arent to big a problem to fit a header. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
