04-22-2004, 12:36 AM | #1 |
Garage Queen Material
brake vacuum line on carb???
where does the vacuum line for the brake booster hook up on holley/demon carbs?
i believe the speed demon i am gonna get has 3 vacuum ports. 1 for pvc 1 for manifold vacuum 1 for ported vacuum. |
04-22-2004, 01:45 AM | #2 |
DAMN, I love Big Blocks!
Usually, these carbs require that you run a "T" fitting, where your modulator valve line connects to the manifold. You will source your brake booster vacuum from there.
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. |
04-22-2004, 01:46 AM | #3 |
i already have the "t" fitting in there.
thats something else i was wondering about. how am i gonna be able to run that with the carb being so much longer than stock? wont it hit it? |
04-22-2004, 02:08 AM | #4 |
My friends demon extends over the rear vacuum port on his edelbrock performer, we just put a plug in it and ran his brakes off the carb, its probably not the best option, but so far it works, I think it should be coming off the manifold though, you get better signal that way. We put a vacuum resevoir on his to help the brakes out a bit too, but hes only running a xe262.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
04-22-2004, 06:11 AM | #5 |
wherever you connect it, make sure you connect it to a port that sees full manifold pressure (since it's pressure lower than atmospheric, not a real vacuum), not venturi vacuum.
04-22-2004, 08:20 AM | #6 |
If you run a spacer under the carb will it raise it enuf to go over the vac fitings?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
04-22-2004, 09:22 AM | #7 |
I would think a 1" spacer should clear a short fitting, may have to cut some threads off to get it lower in the manifold. We can't put a spacer on my friends camaro because with the torker II it had before the performer and a adapter it would crunch a 2" tall air filter. But with OCbauds truck he should have plenty of clearance, i'm running a medium rise intake with a 4" tall filter and think I could run as much as a 6" filter.
04-22-2004, 10:11 AM | #8 |
How much longer is the demon than a regular holley?
I have a hollry now but plan on a road demon soon. just curious.
04-22-2004, 02:40 PM | #9 |
The fuel bowls are slightly longer I think, do you have the 4160 holley? If so I would guess maybe 1/2-1" longer on each end. No gurantees on that though.
04-22-2004, 04:30 PM | #10 |
Slots go on anything!
Doesn't the brake booster fitting screw into the bottom of the carb base on the Q-jet?
1974 Jimmy- 5.3/4L80e/NP241 |
04-22-2004, 04:40 PM | #11 |
Yeah, I believe so, mine is going straight to the manifold port though with nothing else tapping off of it. The port on my Q-Jet is just blocked off.
04-22-2004, 05:31 PM | #12 |
is the stock fitting for the brake booster the same size as the intake port?
also, i think i will only have to have the following hooked up: full: brake booster tranny heater vent thing dizzy pcv nothing on ported. is the pcv a different port? how am i gonna beable to hook all of those up if i only have the 2 ports on the carb? |
04-22-2004, 09:32 PM | #13 | |
