Navel Inspector
kickpanel air vent doors.
Does any one make these? I would like to get a some in really good shape as mine are quite nasty! The rubber seal is really brittle and cracked. I cleanded out the vents and took off the doors( That took a while ) and would like to put some back on that is better condition.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
No one makes the doors new but the seals are replaceable and you can usually clean the doors up and repaint.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Its Magically Delicious
i pulled mine...sanded off the rust, primered and paints ....
you can buy the oval rubber seals through many companies (lmc, chevyduty) ...then drill out the small rivets .... i replaced the rivets with small nuts and bolts ... in case i tear a seal and need to take it apart again ![]()
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
Navel Inspector
Guess I'll give it a try.
I have a couple of sets to work woth.
![]() Join Date: Nov 2002
Duhhhh!
Just did mine. Wasn't smart enough to think of using small bolts, so I pop rivited mine back up - so I can drill 'em out again next time. As Homer would say, Duhhh!
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
Saw this on ebay... check it out
http://cgi.ebay.com/ebaymotors/ws/eB...category=42612
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
Navel Inspector
I bought some cheapo drill bits from the Dollar tree. Not worth a crap. I break the bits so easlily that I thought I would buy two or three sets. They won't even drill into the rivet.
grind off the rivet heads carefully with a dremel and then punch them out ... i forgot i didnt drill them i lightly ground and punched them out
