Old 04-03-2002, 01:19 PM   #1
TC70C10
TC70C10's Avatar
Post Ammeter Gauge needle position ??
I think I have a short or a bad connection on the alternator circuit.
Where does everyones needle sit while the truck is running. My needle is sitting on the 3/4 side of Charge. I had Advance put it on their electrical testing machine and the alternator is putting out 13.5 volts.
1970 Chevy C-10 350,3 spd
1998 Pontiac Firebird
1999 GMC Envoy
Harvest,AL 35749
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 04-03-2002, 03:24 PM   #2
BigJackDaddy
BigJackDaddy's Avatar
Post
13.9V is optimal output, so as far as your alternator is concerned, you're fine with 13.5.
After a normal start with a healthy battery, I expect the charge rate to be high (20 to 30A) for a few minutes as the drain from the Starter is replenished, and then settle down to a trickle level (approx 4A) for the rest of the trip.
The ammeter is not wired to directly measure alternator output, it measures the Charge or Discharge from the Battery. There's a difference. If the reading of the ammeter is consistently high or low, or is indicating a discharge, and your alternator has proved OK then continue checking the belts/battery/regulator/gauge etc.
Jack
1971 GMC 1500; 307 Invader
[This message has been edited by BigJackDaddy (edited April 03, 2002).]
ColoradoMelons.com
BigJackDaddy is offline   Reply With Quote
