Old 04-22-2004, 01:48 PM   #1
ocbaud
Garage Queen Material
fuel pressure regulator mounting???
what would i need to mount a pressure regulator between the inlet fittings on a holley or demon carb?
i've seen it done before. the line from the fuel pump goes to the inlet on the regulator. and then the 2 outlets on it curve up to the inlets on the carb.
ocbaud is offline   Reply With Quote
Old 04-22-2004, 10:50 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
You need to set the regulator before the T fitting rather than what I'm thinking you're wanting to do which would be after that. I know Matt (blackbeast) had that setup like that on his monster engine 406?
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-22-2004, 10:51 PM   #3
ocbaud
thats where i got the idear from
Old 04-22-2004, 10:57 PM   #4
79BIG10
79BIG10's Avatar
You need a pic? I may have one still.
Old 04-22-2004, 10:59 PM   #5
bigblock73
yeller
bigblock73's Avatar
I want to see it.
bigblock73 is offline   Reply With Quote
Old 04-22-2004, 11:08 PM   #6
ocbaud
i was watching the video of our 2002 meet and saw it. i thought it was neat. i was just wondering what fittings i would need to do it. i figured it up with braided hose and an fittings, but dang thats a lot of money. he has it done with chrome pipes and fittings
Old 04-22-2004, 11:15 PM   #7
79BIG10
79BIG10's Avatar
I would use aluminum line from Summit and a flare tool and tubing bender. Steel works but another member showed me how much aluminum is more forgiving and doesn't break like steel
Old 04-22-2004, 11:29 PM   #8
Tom
driving is in my blood
Tom's Avatar
I ran the gas line from the frame up to the regulator on the fender, then up to the fuel line for my holley. I used the second opening for a pressure gauge.
Old 04-22-2004, 11:41 PM   #9
79BIG10
79BIG10's Avatar
Here's the best pic of the engine I have. You can see where the fuel line comes up at the front of the engine but then it goes into a flared T then has equal lenghts to both fuel bowls. This makes the flow even he said. Eric may be able to get a better pic off the video.
Old 04-23-2004, 12:12 AM   #10
ocbaud
Old 04-23-2004, 12:18 AM   #11
79BIG10
79BIG10's Avatar
thanks Eric
Old 04-23-2004, 12:21 AM   #12
ocbaud
thanks Eric
i had to figure out how to do the screen capture.
you have to turn video acceloration down halfway in windows media player, or it wont copy the video when you hit print-screen.
Old 04-23-2004, 01:59 AM   #13
ocbaud
i can take care of the alum. tubing, flaring and bending and so forth, but i need somewhere to order those fittings. i would be getting this regulator:
http://www.jegs.com/cgi-bin/ncommerc...61&prmenbr=361
it uses 3/8 npt
i would like it to look as much like the picture i posted as possible.
the speed demon carb uses 9/16 -24 fittings on the carb
Old 04-24-2004, 12:46 AM   #14
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
So how do you adjust it mounted upside down? What kind of fuel pump you running?
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 04-24-2004, 01:44 PM   #15
79BIG10
79BIG10's Avatar
Eric you're going to have to go to Auto Zone or O'Rilleys and get the fittings. You will need 3/8 male thread with a fitting to fit a inverted flare of whatever size you need for that fuel line to the bowl. Then you need the inverted flare to fit thatfitting you just installed in the regulator. Same thing for the bowl but it needs to be 9/16 instead of the 3/8.
Old 04-24-2004, 02:29 PM   #16
Cole's 87
Cole's 87's Avatar
I'm kinda wondering what fuel pump your running that would require you to use a regulator. There are plenty of low pressure high volume pumps out there that would easily feed your engine. You could spend your money on something else.
Me I would just try to keep your combo simple the more stuff you add the more that goes wrong.
Cole's 87 is offline   Reply With Quote
Old 04-26-2004, 12:53 AM   #17
79BIG10
79BIG10's Avatar
He's running an electric Holey pump I think. With that you need to have a fuel regulator.
Old 04-26-2004, 01:07 AM   #18
low 84
low 84's Avatar
i think he is running the same mechanical holley that i have, which is preset form the factory and dosen't need a regulator
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-26-2004, 01:09 AM   #19
ocbaud
matt or me?
i'm running a 110gph holley
Old 04-26-2004, 02:21 PM   #20
Cole's 87
Cole's 87's Avatar
Eric,
I have the Holley 110 on my big block and you do not need a regulator. I havent had any problems with the pump blowing the float off its seat. I will say that you picked a great mecanical pump it resolved alot of my fuel starvation problems. @ 5500 RPM I still have 6psi
Old 04-26-2004, 04:10 PM   #21
ocbaud
Originally posted by Cole's 87
Eric,
good, i was wondering if it would be pushing to much pressure.
