Old 04-22-2004, 09:10 PM   #1
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
v6 to v8
i have a 63 gmc with the 305 v6. what v8 would fit with not that many mod. and work with a sm-420 tranny? any info would help
kamikazegmc is offline   Reply With Quote
Old 05-12-2004, 05:54 PM   #2
kamikazegmc
Registered Smarta$$
hi found a buick 455/th 400 setup would this be easy to put in place of the 305v6/sm420 setup? any info would help
Old 05-30-2004, 09:24 AM   #3
mattymattel
V6-to-V8
I guess any GM V-8 would work? I've seen a special project truck that GMC did for their '56 version of the Chevy Cameo. It was called the Palimino and it was equipped with the Pontiac 348CI engine and TH transmission, it looked cool. When making the switch, you might want to measure the driveshaft for the length between the new trans output and the rearend. Good luck
mattymattel is offline   Reply With Quote
Old 08-24-2004, 11:04 AM   #4
aggiejon2001
v6
if you decide to scrap the v6, let me know. i might be interested in a few items. do you guys also know what kind of aftermarket carb will replace the stock one? also, what is your opinion on the best vendor for a stock carb rebuild kit or an aftermarket carb. thanks
aggiejon2001 is offline   Reply With Quote
Old 08-24-2004, 02:07 PM   #5
kamikazegmc
Registered Smarta$$
u can go with a holley 2300 it's 2bbl 500cfm, but u can only put it on with an adapter. the web link below can also help
http://www.6066gmctrucks.org/performance.htm
also i havn't found a v8 to put in yet, but i'm going to put the holley on and going to put the pertranix ignitor systme aslo. so it will be a little updated.
Old 08-25-2004, 10:39 AM   #6
60-66 Nut
Professional Beer Tester
Another carburator option for the 305 V6 would be the Rochester 2 Jet used on the 283,307 and 327,if you can find one.They perform better than the stock carb and parts are still available for them.It will bolt right up on the 2bbl 305 intake,I think the 351 has a different pattern.Just a thought.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
