Old 04-23-2004, 01:51 AM   #1
Warbones
Navel Inspector
Warbones's Avatar
Door lock rod removel.
I got the panel off on the donor truck and was wanting to remove the lock rod. I am going to see if I can find info in a book. In the mean time does anyone know how to remove this ?
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 04-23-2004, 07:23 AM   #2
JimKshortstep4x4
Talking
I have always removed it with the door latch. Getting to the clip is a little tough (or my fingers are too fat!).
When installing a latch, I install the rod on first and feed it in.
Jim
Old 04-23-2004, 11:55 AM   #3
dubie
dubie's Avatar
David
There are 3 bolts to remove on the edge of the door and 1 to loosen the window track if you need to move it a bit. Then reach in give it a pull, then a twist and it should drop out. Just make sure the window is all the way up when you remove it. We just replaced the latch assembly on my drivers side door.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-23-2004, 08:09 PM   #4
Warbones
Navel Inspector
Warbones's Avatar
I'll have to give it a try. I need to swap one side on my 67 from the parts truck.
WANTED 1967 IMPALA
