Synthetic or Petroleum Based Gear Lube In The Trans?
Which would YOU put in your granny-gear 4 speed?
I have the Valvoline synthetic in my '72 right now and I am not sure but it seems to shift a little harder than before. Should I go back to the 85-90? Thanx |
![]() Join Date: Jan 2001
back up again
What was I thinking??
Synthetic
For me it's Synthetic all the way. I don't think you can beat Synthetic oil. Now if you think the tranny is shifting harder there could be something wrong in the tranny, I don't see how a good synthetic oil could do that.
Cethern
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
its all about the +6 inches
Keep the good oil in there...you didn't use a lightweight oil did you?
Nope, Valvoline 85-140
Fabricate till you "puke"
I am running Redline synthetic in in my Richmond box(by richmonds reccomendation). the thing you have to watch , is that there is no friction modifiers in the lube(for positrac use). this can cause problems with the syncro blocker rings running too "slick". According to richmond, there are not too many synthetic gear lubes that dont have the positrac addative on the market anymore. i can get a # on the redline lube if you like.....just need to step out to the garage. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 05-06-2004 at 07:36 PM. |
My other Love
I had synthetic in my 3 /12 speed tranny and it shifted nicely, now I put regular oil into it and its really stiff to shift, so I would reccomend synthetic
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Here is a little trick I used to use that I learned from an old buck, doesn't matter what manual trans you have. I used to use it on my harley 4speeds then started using it in customers 5speed jeeps that use to have real hard time shifting. I used to use BG engine concentrate, something like STP, put about 1/2 cup or about half the container in the trans and it will shift like cutting warm butter. I have had a lot of customers compliment me after having to rebuild their trans because of broken forks from trying to get it in gear and on how easily it shifted afterwards and that it had never shifted so nicely. I've used on many different transmissions.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
I like RP and redline gear oils. As far as redline goes........MTL, MT-90 and 75w90NS are all designed for manual tranny applications. IIRC the 75w90NS is a GL-5 fluid, so you must not use it in appications that spec a GL-4, for most GL-5 fluids are corrosive to soft yellow metals. All three of the aforementioned fluids have different viscosities and will give different shift feel, so experimentation is recommended. The MTL and MT-90 can be mixed to give a specific shift feel. RP max-gear 75w90 is GL-4/GL-5 rated fluid so it is safe for soft metals.
Nobody has mentioned it yet so I will . . . . .
The only caution about synthetic in old vehicles is that if the gearbox, rearend, pwer steering pump, motor etc is old, the seals may start to leak when you put in synthetic. It does such a good job cleaning up the old seals etc. stuff often starts to leak. I know this from experience (the hard way). If it is a new motor, trans, gearbox, etc. then it is a diffrent story. but a 30+ year old unit? Be warned. Just my .02 Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
While I have read that over and over, I have chainged over will over 100 engines of variouse mileage to synthetic...my wife's 70K contour, all the way to our 92 F-150 with 227K and all original unopened engine....none have ever come back with a new leak.
Not saying it isn't true, see too many ppl claim it to be true...just reporting my observations. |
I agree with Andy-never had synthetic stop or start a leak.
#13 |
A local trans shop owner with like 40 years in the business uses Mobil 1 TRANS fluid in his personal vehicles and swears by it. I had a 97 C5 Corvette with a 6 speed that was notorous for occasional shift failures-not speed shifting but going into 1st gear from neutral -would give you the feel of the detent but not actually getting into the gear. He suggested Mobil 1. Within a 1/4 mile from my install, the gearbox felt different and didn't fail once in the next 10K miles where it would about every 20 miles before. I sold it without one failure after the Mobil 1 swap.
