Old 04-23-2004, 01:00 PM   #1
72moneypit
72moneypit's Avatar
Question Mini starter, heat shield, or remote solenoid?
Well, the warmer weather is coming and once again I'm faced with starter-related problems due to heat. I'm determined to fix the problem for good this weekend, and I'd like to hear your opinions/experiences on the best way to do it.
I've heard of three alternatives:
1. Install a heat shield to insulate the starter from the exhaust manifold. Shield deflects heat away from starter/soleniod.
2. Install a mini starter/solenoid. Because it's smaller, it's farther away from the heat source.
3. Install a remote starter solenoid that essentially reroutes the wiring to a Ford-like solenoid mounted away from the engine.
I'd be interested to hear about anyone's opinions and/or experiences on these options (or other methods). Thanks!
Paul
72 Cheyenne Super Custom Camper
greenaz@hotmail.com
72moneypit is offline   Reply With Quote
Old 04-23-2004, 01:08 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
I did the remote starter solenoid from Jeg's or Summit and sure was easy and fixed my hot start problem. It was like $22, you can probably do it yourself for a little cheaper, but that was fine for me.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-23-2004, 01:23 PM   #3
rodnok1
rodnok1's Avatar
Alot of starting problems can be traced to bad wiring, replace all the wires going to the starter to include battery cables, up size the battery cables also. Don't buy a cheapo starter, they won't last long even on stock or fairly stock engines. Oil leaking onto the wires and starter will also make it worse. Also make sure you have excellent grounds from engine to battery and to frame, that way you ensure proper voltage to starter. I switched to a mini starter, but not because of heat, I needed a better starter to crank my engine with high compression. The remote selenoid is also a great idea, mainly because then the wiring doesn't get heat soaked(that's why I change mine ever few years) the wires can only take so much then the lose the ability to pass full voltage. Good luck.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-23-2004, 02:11 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
I also have the remote solenoid and never fails. I dont know how its hooked up, but it works.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-23-2004, 02:32 PM   #5
busterwivell
I was going thru a starter every six months. Ihave a 402 with stock manifolds. I put on a mini-starter in August of '01 and it's still working fine. Problem solved.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 04-23-2004, 03:07 PM   #6
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
I did the heat shield ($8.00) on a stock starter and it works fine so far. After I get the headers on I might save up for the mini-starter, I've heard (here) that its worth the extra money.
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 04-23-2004, 04:07 PM   #7
67chevemall
67chevemall's Avatar
Mini Starter 4 sure
And home made heat sheild from newer car!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-23-2004, 04:28 PM   #8
BET68
STARTER
FOR THE MONEY GO THE REMOTE, JUST MY VOTE
NAMASTE
B&E
1971 LONGHORN C-30
1969 LONGHORN C-20
1968 DUALLY
1970 STEP SIDE PROJECT
1972 CST C-20
1980 M-80 MALIBU FOR SALE
1974 NOVA FOR SALE:
BET68 is offline   Reply With Quote
Old 04-23-2004, 06:56 PM   #9
'70_402
'70_402's Avatar
I have never had a problem with my starter...402 with stock manifolds in the scorching hot of texas.
(what happens to me won't happen to the next person though...thats my luck)
'70_402 is offline   Reply With Quote
Old 04-23-2004, 08:44 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I vote "D"!! Since you're there go for it all.That way you've only had to do it once.Maybe a wrap around your headers too.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-23-2004, 09:53 PM   #11
72LOWBOY
If you're running headers and fairly high compression motor.I would definately run a mini starter.That should solve all your problems. As long as the wiring is in good shape.
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work.
68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife
38 Chevy Coupe on the back burner
LIFE IS GOOD! SMILE
72LOWBOY is offline   Reply With Quote
Old 04-23-2004, 10:39 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have the heat shield and it work's really well for me... Just my 2 cent's...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-24-2004, 12:21 AM   #13
72moneypit
72moneypit's Avatar
Thanks everyone for your feedback. I think I'll try the remote starter solenoid and see how it goes.
Paul
greenaz@hotmail.com
Old 04-24-2004, 01:07 AM   #14
kwmech
I put the remote solenoid on all my trucks along with the heat shield. Advantages are for one the hot start problem, 2 is the ability to crank the engine over very easily when servicing the truck, 3 all the battery wires and charging wires are not buried behind the engine block and getting burned and oily and 4 being able to change the starter a lot easier [when needed], and not to have to disconnect the battery and losing all the memory in the stereo.
Old 04-24-2004, 01:21 AM   #15
barn9
Half a bubble off!
barn9's Avatar
I went with the remote solenoid, and it solved my problem. I plan to go with a mini-starter one of these days though.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-24-2004, 01:25 AM   #16
crazy longhorn
Fabricate till you "puke"
Guys, im really confussed......I have never had a problem with a starter on these old trucks! IMO, you need a good battery, good set of batt cables, a good starter. I run headers, no heat sheilds, no remote soleniods. Im running a sb that kicks 1 hp per cube, & is almost 10-1 comp ratio......i do not have any hot start issues,& I never have .......not even with a 461" Olds @ 10 to 1! Not an arguement, but just the facts Jack crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-24-2004, 03:18 AM   #17
454_72_4X4
454_72_4X4's Avatar
I run the remote solenoid on all my Chevys.
Don't waste your money on the "kits" though.
It's a VERY simple setup.
I'm not very good at explaining things but I'll give it a try.
1. Buy a normal old F@&D solenoid.
(Doesn't really matter if is has 1 or 2 of the small posts unless you're still running a points type distributor.)
And you'll have to buy or make a double eyelet battery cable, but you need to mount the solenoid first so you can get the correct length.
2. Find a suitable mounting spot for the solinoid. (Now get the above mentioned cable)
3. You'll have to run the positive cable from the battery to the solenoid, (one of the big posts, I don't thinkit matter which one), and run the double eyelet ended cable from the other big post on the solenoid down to the starter post.
4. Now you'll have to lengthen the "start" wire, (usually 10-12 gauge purple wire), so it will reach the new solenoid and attach it to the "start" post.
You'll have to lengthen the 12v points lead if you're still running pionts also. You're on your own there. (Mines been gone to long to remember about it).
5. Now comes the only "trick" to the whole thing. You'll need to fabricate a small metal strap with one small hole and one big hole to connect the main battery cable post on the starter solenoid, (not the remote solenoid), to the small "Crank" post, (the one where the purple wire used to hook up).
One thing to watch for when you make this strap connector is to make sure it doesn't touch the bottom solenoid post. If it does the starter will engage as soon as you connect the battery! Not good!
I like to use copper to make the connector strap out of and the easiest place I've found to get it is just a normal piece of copper tubing. You can smash it flat or split it open and cut it to shape with a good pair of tin snips. I like the split it open version better myself. looks a little cleaner.
I've been running all my Chevy's with this setup for about 15 years or so and have never had a problem with "hot start" and I've only had maybe 2 solenoid go bad, (the chevy ones on the starter).
Another thing I forgot to mention is, I think, (might be wrong here), that the ford solenoid will have to be grounded to work properly.
WOW, that was a lot of typing for a 2 finger guy!!!LOL!
Good thing it's a SIMPLE setup, Huh?!!
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-24-2004, 02:16 PM   #18
Jeepster376
Jeepster376's Avatar
I don't understand. From this description it sounds like you are adding a remote starter solenoid in series with the starter mounted solenoid. Now you have two solenoids instead of one. How does this help? You still need the chevy starter solenoid to be functional, for contacting the 12V to the motor, and to engage the bendix gear to the flywheel.
If you changed to a different type of starter without a piggyback solenoid that would be another story, but this isn't the case.
It sounds like in your description you jumpered the battery post to the start terminal, this would trigger the solenoid any time the batery post is remotely powered but still routes power through the solenoid's contacter. Wouldn't you want to jump to the motor input, bypassing the solenoid contacts? You would still need to jump to the start terminal also i believe as the solenoid still has to activate to engage the bendix.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-24-2004, 02:55 PM   #19
454_72_4X4
454_72_4X4's Avatar
You read it correctly Jeepster.
You'll end up with 2 solenoids, (the original Chevy and the remote F@rd one). Seems like extra BS doesn't it! It does work well though.
I can't really remember exactly why it works but it's something to do with "heat soak" and then something about the chevy type solenoid takes alot more amperage to activate than the Ford type.
Instead of the purple wire having to carry the extra amperage to activate the chevy solenoid you have full amperage straight from the battery, (through the remote solenoid and the battery cable), to activate the solenoid.
I also like this setup for the reasons kwmech stated.
Another reason is if you've ever had a positive cable short out against the manifold, (leaves you walking if you're lucky), this cures that too. Even if the cable does somehow come in contact with the manifold, (or headers), there's no "power" there until you hit the start switch.
I did have one rather "different" experience with my setup once though. On my 72 before I went to the newer style bellhousing, (it had the old style that the starter bolted to the bellhousing), I drove to work one morning and just happen to driveby my truck sitting in the plant, (I work road construction), and noticed something hanging under the truck. Closer inspection and I found out it was the starter hanging by the cable! One bolt had come loose and then the other two ears on the starter broke off. I don't know how long I drove with it hanging like that!
On the good side, my truck is a stick so I just unbolted the cable at the remote solenoid, threw the starter in the back, had a friend pushstart me and drove home.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 04-24-2004, 03:24 PM   #20
Jeepster376
The shorting out point is a good one. I also had a starter fall out of one of my cars once to dangle by the cable.
