reverse rotation water pump?
I just purchased a new water pump but when I opened the box there was something about it being a reverse rotation type... I will not be using a serpentine belt setup for my accessories, will this work with a "normal" v-belt setup?
thanks! |
![]() Join Date: Mar 2003
I would return the pump and get a correct one, if the tag in the box said reverse. And no it will not work, sounds like a misboxed part.
Fabricate till you "puke"
2nd that! the pump wont work with V belts.....crazy L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
thanks for the info... i'll be getting a new one tomorrow!
