Old 04-24-2004, 01:35 AM   #1
cheyenne10
cheyenne10's Avatar
dana 60 rear worth
What is a complete dana 60 4.10 posi rearend worth? Can one be sucessfully converted from 2 to 4 wheel drive? What to what for in converted unit?
thanks.
Bob
cheyenne10 is offline   Reply With Quote
Old 04-28-2004, 02:32 AM   #2
500HP/SB
please don't break
500HP/SB's Avatar
my neigbor/friend offered me a complete dana 60 with 4:56's and a posi for $400. i dont know if this is fair or not, but i'm thinking about snatching it
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 04-28-2004, 05:52 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'm assuming it's a coil sprung rear since you say convert from 2wd to 4wd. Most of the dana 60s were leaf sprung though even in the 2wd. That could be a factor. The 4.10s are not that uncommon but the posi can be rebuilt(should be a powr-loc). If it was open and had 4.56s and on the east coast I'd give a couple hundred.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-28-2004, 10:23 AM   #4
cheyenne10
cheyenne10's Avatar
leaf spring
I agree most if not all dana 60's I've seen are leafs. I beleive leaf perches on 2 wheel drives and 4 wheel drives have different pad seperations though. I would assume good welder could cut off old ones, grind smooth and put new ones in proper location. I thought there may be difference with axle dia., brake specs or overall width.
Bob
Old 04-28-2004, 12:31 PM   #5
1969 GMC
1969 GMC's Avatar
coil sprung dana 60's came behind a 396/402 in c/20 trucks and burbs. since it has leafs, it most likely came from a GMC c/2500 non big block, but that is pure speculation on my part. it is possible to grind off old leaf perches and weld on new ones, but you have to be careful so you don't warp anything. i am going to do the same thing with my HO52, as it originally came from a coil sprung c/20.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
