Old 04-24-2004, 01:14 PM   #1
69ride
All Go, No Show
69ride's Avatar
HELP! truck won't crank
I just put the cab on and wired up the ignition, new soleniod on starter. Battery has 12.50V. 12.50 volts at starter, 12.50 volts at alternator. Jump in the cab, turn the key, nothing. multimeter shows 12.50 volts at starter. now the history..
When I took the starter off it had a wire going to the R terminal and a wire going to the s terminal. The truck has HEI installed on it so I don't need the wire going to the r terminal right?
Second question the wire that i clipped off going to the r terminal was white not yellow and it was tied in with the wire that goes to the distributor(pink) at the firewall connector, should this wire go back on the r terminal?
The ignition switch i have was given to me so i don't know if it works or not. I am going to go back out and see if i have power going to the switch. and hopefully when i come back in there will be a mess of info on here
Hope this is as clear as mud.
the engine is a mid 80's 305 and the cab and ignition switch are from a 67 GMC c10
Thanks in advance guys and girls
69 LWB
Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI.
69ride is offline   Reply With Quote
Old 04-24-2004, 01:51 PM   #2
cdowns
cdowns's Avatar
do you have the wiring hooked up to the syeering column especially the purple wires going to the neutral safety switch?? you also must get rid of the original wire going to the distributor(original wire is a resistor not supplying a full 12volts)
Old 04-24-2004, 02:31 PM   #3
69ride
All Go, No Show
69ride's Avatar
i got it!!!
I firgured it out. took ignition connector off and i wasn't getting 12 volts to the key. i looked over my harness again and again. Dummy. I didn't have the main red wire that feeds the key hooked up. Hooked it up and sure enough she wants to roar to life. now to set the timing..
69 LWB
Old 04-24-2004, 05:44 PM   #4
Slams_58
YAY Dustin...now how bout ya mosey on over to Copco and get Tim's roaring too!
Slams_58 is offline   Reply With Quote
Old 04-24-2004, 05:52 PM   #5
69ride
All Go, No Show
69ride's Avatar
he would probably love that. He better have that thing on the road by may long or that 10 bucks is mine
69 LWB
Old 04-24-2004, 06:44 PM   #6
Slams_58
I thought more was at stake. I'll get the thing running just so you don't get the $10!!!
