Old 04-24-2004, 04:31 PM   #1
classicchev
classicchev's Avatar
changing ignition
Im putting new keys in my C10, having a problem getting the old ignition out. Is there a special position for the key to be in to pull it out???? Thanks Darren
classicchev is offline   Reply With Quote
Old 04-24-2004, 04:52 PM   #2
crazy longhorn
Fabricate till you "puke"
turn the switch to acc, & use a pin or small allen wrench in the small hole on the face. while pushing in on the pin, continue to turn the switch to the left, & the lock & key should pop out.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-24-2004, 06:17 PM   #3
classicchev
got it, lots of giggling. Almost need three hands.
