Old 04-25-2004, 02:01 AM   #1
Penix
Penix's Avatar
Will 86' GMC rear end bolt right up to my 66' C-10?
Like the subject lines says, I wanna know if the rear end from an 86' will bolt up to my 66' C-10.
any help would be greatly appreciated.
"Don't get on it if you can't stay in it" "How do you call yourself a man when you're ride'n a pony?"
Penix is offline   Reply With Quote
Old 04-25-2004, 07:18 PM   #2
zenish
no,its 1.5" wider and the brackets are different. www.earlyclassic.com sells the brackets you need to install it.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 04-27-2004, 02:54 PM   #3
kewlbear
No, but i just seen a kewl kit from Chevy Duty. Kinda pricey but
it makes any 73 to 87 rearend work as long as it is 61" from backing plate to backing plate. Comes with axle seats, adjustable track bar and track bar mounting brackets. Just need a welder.
64 Chevy pickup
tilt,pb, ps discs up front
350/TH350, 72 rearend
auto meter gauges
93 GMC extended cab
trailmaster conversion
kewlbear is offline   Reply With Quote
Old 04-27-2004, 08:16 PM   #4
Penix
Penix's Avatar
Wish I knew an affordable welder in my area! Oh well, I'll just look for a stock rear end for it then... The original 6 lug (what were they again? Dana something I think) was taken out and a 5 lug was thrown in. True, it drives well on the freeway, and I'm sure the original gearing was lower, but I've got a freshly rebuilt 700R4 for it and I'd like to be able to use the same rims on it front and back. I like the 6-lug look too. I want a work truck / daily driver, so I figure lower gearing along with the 700R4 would give me want I'm look'n for... Anyone know where I can get ahold of a stock rear end for this thing?
Hey, is a 66' GMC 1/2 ton still considdered a C10? It's a SB Step Side with a... 292 if I remember right.
