Old 04-25-2004, 03:56 AM   #1
kickinasphalt
kickinasphalt's Avatar
Just picked up 71 K-10...lift kit is first on the list and have questions
Hello everyone! Haven't been around here for quite some time. Picked up a 1971 K-10 long box today with a 350 and 4 speed. This is gonna be my new project. First on the list is a lift and tire/rims (because stock tires and suspension is just too small )I've been looking around at lifts and there seem to be a few to choose from. I plan to keep the small block and since I don't tow, I don't need 'heavy duty' springs. I know I want all new springs all around and shocks too. Ride is kind of important (I don't want super harsh ride). I haven't decided between 4" with 33's or 6" with 35's so I was wondering if anyone could point me in the direction to find some pics of both. I came across the Tuff Country brand when searching and found this 6": http://www.suspensionconnection.com/...on/166114.html Is this a good deal? Its almost the same price for a 4" so price wouldn't be a factor for choosing between the two. Thanks much and remember I nee pics!
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 04-25-2004, 11:55 AM   #2
ryanroo
ryanroo's Avatar
i have a skyjacker 8 inch on mine, thinkin back i would have ordered it for a half ton to be a little softer, but overall the ride is good. a 4 or 6 inch woul be better yet. sorry no pics
ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-25-2004, 01:35 PM   #3
Destructo
6" Tuff Country EZ-Ride suspensions with rear springs would be my choice. I have a 4" rough country kit on mine and it is VERY stiff. I have heard Tuff countrys EZ-Ride kits ride better than factory. Flex very well also.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 04-25-2004, 01:48 PM   #4
kickinasphalt
Besides the steering arm drop, is there anything else required for a 6" lift (like driveshafts etc.). Thanks.
Old 04-25-2004, 04:31 PM   #5
ryanroo
ryanroo's Avatar
with six inches i imagine youll need driveshafts lengthend, and front brake lines for sure, the bracket on the back may be able to be bent so it works, but its easy to replace so why not. when i got my driveshafts, my shop told me they don't carry the big tube that was stock for the rear, they could get it, but at some ridiculous price per inch so i ended up gettin new ends to
Ryan
72 K20 12v build
Old 04-25-2004, 11:51 PM   #6
Budweis
Geared for Collision
Budweis's Avatar
some of the kits come with transfer case drop kit and dont have to lengthen driveshafts and some dont from what i understand.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 04-26-2004, 06:15 PM   #7
kickinasphalt
I went back to the site and looked at the bill of materials:
EZ-Ride front leaf springs 2
EZ-Ride rear leaf springs 2
U-bolts 8
Transfer case drop kit 1
Sway bar drop kit 1
Brake line extension kit 1
U-bolt - nuts and washers 2
Spring bolts - rear 4
Spring bolts - front 4
Looks like it comes with a transfer case drop. My next question is how does this work? How can you just 'drop' the transfer case?
Old 04-28-2004, 02:10 AM   #8
500HP/SB
please don't break
500HP/SB's Avatar
Hope i can help, this is a 4in lift with 35"s, for my next tires i may try some 33"s
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 04-28-2004, 02:11 AM   #9
500HP/SB
please don't break
500HP/SB's Avatar
ooops here
titanspeed.com
Old 04-28-2004, 06:07 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Those tc drop brackets will not work on trucks with the torque type mounts. They are for the trucks w/ the cross member/skid plate only. i.e on both my trucks the cross member is under the tranny/tc adapter and the tc has a mount on the left side only. I don't believe you can drop those types of mounts.
Definetly go 6", your front drive shaft should have a double cardian joint at the tc already and should be fine. In the rear all you should need is length. "Dropping" the tc is for u-joint angles and if these are a problem it would be better to get a double cardian drive shaft made for the rear.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-28-2004, 02:12 PM   #11
kickinasphalt
My engine, tranny, and transfer case are out of an 1980 Chevy 4x4. Will this make any difference for anything?
Old 04-28-2004, 03:00 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Post a pic of the tc from the rearend.
Old 04-28-2004, 03:23 PM   #13
1969 GMC
1969 GMC's Avatar
1980 would be an SM465 mated to a slip yoke NP205. The transfer case still has the torque mount (or at least the holes in the actual transfer case for it, I got my '80 combo already pulled and thats what I'm going by).
there shouldn't be a sway bar on your truck, they didnt come from the factory until '73. are you looking at the correct lift kit?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-28-2004, 04:20 PM   #14
kickinasphalt
Can't at the moment...pickup is 370 miles away back home (I'm at college). Will when I can.
Here is the link again: http://www.suspensionconnection.com/...on/166114.html
Thats what is says.
Old 04-28-2004, 10:59 PM   #15
454_72_4X4
454_72_4X4's Avatar
I've got the Rough Country 4 in. "soft ride" / "easy ride"lift on mine and there's nothing soft or easy about it!
I had to have a new front drive shaft made. My slip joint was wore out anyway.
I found a rear drive out of a longbed F@rd Ranger, (I'm pretty sure it was out of a Ranger anyway cause it was in the bed of it and it has a F@rd emblem on it), and had it shortened to fit. Had to do a little grinding on the yokes for clearance cause of the driveline angle.
My rear drive shaft would have worked but it was wore out too. I had a new shaft built cause the driveshaft shop told me they could build a complete new shaft, (3-1/2 in.) cheaper than the cost of the slip joint for the big, (4-1/2in.? can't remember), pipe.
My brake lines could have been made to work also but I replaced them with the stainless steel ones.
You'll also need the raised steering arm to make it drive good.
I just got the motor back in mine today. I'll take a couple of pics when I get it out in the daylight.
One other thing I'd like to mention. Almost every lift kit I've seen leaves the rear of the truck sitting lower than the front. I think they look like chit that way. Mine was the same way so I flipped the rear shackles also to bring it up just over level. (rear higher than the front).
Rear shackle flip is simple on these trucks.
Cut, grind, or drill out the old rivots, flip the shackles, weld them back on, and add some gussets.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
