Old 04-25-2004, 01:12 PM   #1
72'BBGMCSGCC
Question stock GM Hei ground wire ?
I'm putting a stock GM Hei in my 402BB and I noticed on the plug that plugs into the dist. cap (black wire on the plug) has a electrical connector , but in the dist. cap there is no electrical plug for the black wire to plug into. Is there suppose to be one and where does it hook up to? and any info would be helpful. Thank you
72'BBGMCSGCC is offline   Reply With Quote
Old 04-25-2004, 01:38 PM   #2
kwmech
There should be a wire or thin metal strap that goes from the coil mount [one of the 2 front holes] to the center of the 3 wire connector. If the strap is not there you will fry the module over a short period fo time.
Old 04-25-2004, 01:44 PM   #3
72'BBGMCSGCC
There is a black wire or strap inside from the coil that is bolted on one of the 4 bolts that holds down the coil. what other wire do I need and where does it go? Thank you
Old 04-25-2004, 01:47 PM   #4
72'BBGMCSGCC
where do I get the wire from the coil mount to the 3- wire connector? Thank you
Old 04-28-2004, 10:49 AM   #5
72'BBGMCSGCC
Thank you KWMECH I appreciate the info, I picked up one of the straps at NAPA yesterday . Thanks again. Dave
