SOON TO BE A STEP SIDE
Knobs And Ignition Switch
HOW DO I REMOVE THE HEADLIGHT SWITCH KNOB? (BLACK PART)
I HAVE THE TRIM RING LOOSE AND THE NUT LOOSE DOES IT PULL OFF? ALSO I LOOSENED THE IGN SWITCH RING AND IT SPUN BUT IT DOES NOT SPIN OFF I WANT TO REMOVE THE SWITCH ASSY FROM THE DASH THE ELEC PLUG IS REMOVED FROM THE REAR OF THE SWITCH
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY! 4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON |
PIC 2
Try spinnin 4 rear tars
The headlight knob is removed by pushing a button on the top of the switch. Reach up under the dash and on top of the switch assembly there is a little button. Push that down and the knob will pull right out. Remember your lights will stay on. To put it back in, just push the knob in, you don't have to push the button.
As for the ignition switch, I don't know.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
KEEP ON TRUCKING
on the light switch reach up behind dash to the switch you will feel a little button on top of the switch push it down while pulling the knob out and it should pop out.cant help on the ign i tore the last 2 up that i tried
72 cheyenne 2wd lwb 71 k20 sons bassett va |
when i pulled my ignition i had the same problem. find a paper clip. turn the key to acc and put the paperclip into the little hole next to the key hole. you will feel it push a button in. hold the paperclip in the hole with a little pressure then turn the key to the left. the barrel assy should come out. then you can remove the rest of the ignition. hope this helps
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
Half a bubble off!
The headlight knob and stem are one piece, and it's usually a good idea to unhook the battery.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
THANKS FOR THE TIPS
3 MINUTES LATER AND BOTH ARE OUT AS COMPLETE UNITS NOT SMASHED TO LITTLE ITTY BITS NOW IF SOME ONE CAN TELL ME HOW TO GET THE LIGHTER SOCKET OUT OF THE DASH IT WILL BE A CLEAN SWEEP
#8 | |
Inline 69
ANOTHE 2 MINS AND MY DASH IS CLEAR
GETTING READY FOR SANDBLASTING ENTIRE CAB THANKS
