71 c-20 wont turn over
with I New battery ... how do ya ck the starter ?
hmm...
so I take it it's not turning over? Does it tick or make any sound at all? If so, you might have a bad starter or soleniod. If not, you could have a gimp solenoid, bad wiring in any part of the starting system or a bad battery (yeah, new ones can be bad too).
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
All Go, No Show
check all the wires going to the starter first. Get the battery load tested ( it can be fully charged and yet still be junk). If everything checks out fine with those two things, turn on your dome light and try to start it, if the light remains as bright as it was before craking then thre is an open somewhere in your cranking curcuit if the light goes REALLY dim or out then there is likely a short or ground in your starter. a good battery should only go down to 11 volts when cranking and a weak one will go down to about 10 volts or less. hope this helps
69 LWB Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI. |
its all about the +6 inches
what kind of bettery?
Why was it replaced? What do the cables look like? Do the lights work? do they dim when you try to crank it? How old is the starter...and are there headers there? Is the truck in park? |
Ooptima new red(truck did not have battery ) cables look good...lights do work Yes light do dim dont know how old the starter is .. headers yes and in park .......................
![]() ![]() Join Date: Jul 2002
I usually check my starter with a voltmeter and check the voltage drop when it tries to crank. If it drops much below 9V, then chances are battery or starter is bad. From the sound of it sounds like you have nothing, so I'm not sure that will work.
On a side note, did you try it in Neutral instead of Park? Maybe the safety switch is funky.
i got a chevy man(24 years old ) from the store .. coming over and taking it to his dads or uncle shop woooo hooooooooooooooooooooooooooooo he tried the volt meter .. so new starter .. thanks guys
