Old 04-25-2004, 08:35 PM   #1
Mountain Man
Installing 88 - 94 chev seat Questions
How hard is it to install an 88 - 94 bench seat in our pickups?
Can I use original sliding brackets, and bolt new seat to them?
How would the 88-94 brackets fit in our truck?
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 04-25-2004, 08:50 PM   #2
It is real simple. I like using the brackets that came with the 88-94 seat. You sit a tad higher but I prefer it myself. You line it up with the front two original seat holes. On the back you'll need a 1" spacer (I used a 3/4" to 1/2" pipe adapter). Drill two holes, and bolt it down good. I have compression washers on the underside for added strength.
here is front mount position
Old 04-25-2004, 08:51 PM   #3
here is rear mount. To me this was the best thing I ever did to my truck. Comfort level is no comparrison to me
Old 04-25-2004, 09:00 PM   #4
1972C10
1972C10's Avatar
If you slide the brackets back behind that hump where the factory seat mounts it wil make it lower and take the lean back out of it.
I have had full bench out of the 88-94 and the 60 40s and now a set of 40 40 buckets and mounted them all like this when i got the truck they were mounted like pictured above and for me 6'8 that didnt work too well so i checked it out and slid them back behind that hump and it lowered the seat about 2 inches and give more leg to steering wheel clearence.
1972C10 is offline   Reply With Quote
Old 04-25-2004, 09:23 PM   #5
gr8scott51
gr8scott51's Avatar
I'm with 1972C10, I had to drill 4 holes, but I think it sits better.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 04-25-2004, 11:57 PM   #6
CG
BlahBlahBlah
your 6'8"? how the heck do you fit in the truck? im only 6' and i wish i could slide my seat back further.
Old 04-26-2004, 02:45 AM   #7
1972C10
1972C10's Avatar
Very Carefully.
I removed my gas tank from behind the seat wich gave me a few more clicks back on the seat Isnt really that bad For a long time my knee rubbed on the instruemnt cluster since i took the gas tank out it no longer rubs.
Old 04-27-2004, 03:17 AM   #8
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
Are you guys talking about a 88-94 bench seat from a truck or from a full-size passenger car or from a van???
I want one already, and I have no idea what they look like!
Stepsides 4Ever is offline   Reply With Quote
Old 04-27-2004, 10:58 AM   #9
gr8scott51
gr8scott51's Avatar
Mine's from a Silverado. I'm sure all of these guys are talking pickup seats.
Old 04-27-2004, 11:05 AM   #10
Mixup
I cut and rewelded the seat brackets when I put the late model seat in so it would sit flat on the floor.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
