Old 04-25-2004, 09:52 PM   #1
rn2fine
rn2fine's Avatar
??? Rearend Buildup For High Power
While I was working on my Burb today a young man from down the street came by. He has a 68 shortbed with a 6 cylinder and a 10 bolt rearend. His dad bought him a 454 that is being rebuilt. His plan is to put a 280 cam in the 454, run a Performer RPM intake, and attach it to a TH350. His dad is recommending that they find a way to put a Ford 9" in the rear. I told him that I would check with you guys to see how to buildup his existing rearend to handle the high horsepower and torque of his new motor. Once again, he has a 10 bolt, and it has 4.11 gears. Can it be beefed up? Should he switch to a 12 bolt? Or should he pursue the Ford 9 inch? He is also trying to decide on a rear end gear ratio. He plans to use the vehicle daily and do some racing on the weekends. I will pass along your advice to him.
Thanks !!!
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 04-25-2004, 09:56 PM   #2
Autometer
Autometer's Avatar
I'd just go with a 12 bolt. Fine one that bolt right in and that'll keep his GM truck all GM.
'05 Silverado
'02 Avalanche
'85 C10
'71 C10
'51 3100
Autometer is offline   Reply With Quote
Old 04-25-2004, 09:56 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
I think a 12-bolt should be fine and easy to put in. That truck shouldn't have a 10-bolt stock, it would have been swapped in later. 12-bolts are the only rear to come in half-ton Chevies of this vintage. Some early GMC's had Dand 44's in the rear though.
Member bigjimzll is running 11 second quarter miles with a 12-bolt truck rear.
10-bolts are weak rears stock, one of my friends completely destoyed an 8.5" model in an '86 K10, with a sick 305 in front of it. The thing pretty much came apart, without even 150k miles on the clock.....some how the crosspin wallowed out the hole in the inside of the carrier, came out, and it let go of an axleshaft. I've had problems with 12-bolts, but it has all been because of them getting worn out with ultra-high mileage, not breaking parts.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-25-2004, 10:55 PM   #4
rage'nrat638
rage'nrat638's Avatar
heavy foot
FATHER KNOWS BEST
rage'nrat638 is offline   Reply With Quote
Old 04-25-2004, 11:00 PM   #5
71Rat
ran out of money
71Rat's Avatar
i would go with a 12 bolt and a nice posi. my friends uncle is running a malibu with a 383 turbo 400 and a 12 bolt. the car runs 10 seconds every day of the week and will break into the 9's without a problem except for they dont want to go through an NHRA license process. so i would find a 12 bolt and toss it in the back. and yes the car 12 bolts are different then truck. the pinion shaft on a truck is thinner then a car. if the car was going to be race only then i would opt for the 9 inch. but thats only after you have enough power to blow up a 12 bolt. if the kid wants to do a little work from street to track then he can get a 9 inch and swap 3rd members when he wants to go racing..... just have one set up for the street and one for the track...... could even swap them at the track if need be.
hope this helps somehow
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 04-25-2004, 11:02 PM   #6
cdowns
cdowns's Avatar
if he's going to spend alot of money on the rear i'd say go with the heavier duty 9inch
Old 04-25-2004, 11:06 PM   #7
rage'nrat638
THE HOUSING ON A CAR 12 BOLT IS MUCH BETTER THAN A TRUCK 12 BOLT.....
THE HOUSING IS THICKER AND STRONGER TO HOLD UP TO THE STOCK HIGH H.P. THAT CAME IN CHEVELLE'S MALIBU'S CAMAOR'S
ETC....TRUCK'S NEVER HAD HIGH H.P. THEY ARE MADE DIFFERENT
Old 04-26-2004, 12:14 AM   #8
stllookn
Saving 1 truck at a time!
stllookn's Avatar
ragenrat, Does that mean a stock truck 12-bolt will not take a 500+ hp 454? I am wondering too since I hope to get my rat into my short fleetside and if not just for alot of smokey burnouts! It would be fun to turn some 12's or 11's. Is BigJim running a stock truck 12 bolt? If so, I am good to go!!!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-26-2004, 01:01 AM   #9
rage'nrat638
no sure about jim...but i blasted my 12 bolt truck rear end about a 1/2 block down the streetDOHOO AND broke 8 valve springs after the engine rev'ed past 7200 RPM....very costly fubar
not to speak about the 1200.00 i had dumped into it
this is what it looked like before i blased it
Old 04-26-2004, 01:20 AM   #10
1969 GMC
1969 GMC's Avatar
is the truck 5 or 6 lug suspension? sorry if i missed that...
but anyway, the semifloating dana 60 is stronger than the Ford 9 inch, and came stock in some GM trucks. also came in hemi mopar cars. or, you could even go for a semifloat 14 bolt axle, but both the SF d60 and 14b have a 6 lug pattern.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-26-2004, 09:08 AM   #11
71Rat
ran out of money
71Rat's Avatar
some semi floating 14 bolts were 5 lug.... the 454SS's came with a semis floating 14 bolt and 5 lug
Rat
Old 04-26-2004, 11:08 AM   #12
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Will an Eaton or 14 bolt FF hold up to that power?
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
