04-26-2004, 01:26 AM | #1 |
Radiator swap..... 3 core to 4 core.
ok, its about time i get my radiator replaced. current one has a really bad leak, bar's leak wont even fix it. what all do i need? so i dont have to run around while i am trying to do it. Do the brackets interchange? looks like there could be enough room to work.
04-26-2004, 03:30 AM | #2 |
There's enough room, but you will need the upper and lower brakets....
And you will need to bend or cut the lower lip and bend it to allow for the larger brackets.... Simple job..
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
04-26-2004, 04:40 PM | #3 |
BeWarE tHe eViL CrAnkTOe!
I thought we went over all this Jon?? hahah
I even gave you part #'s
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
04-26-2004, 09:31 PM | #4 |
you need the upper bracket which is just one big piece that mounts over the radiator. i got mine from chevy duty for like 15 bucks or something. you'll also need 4 of the wider rubber mounts ( 2 for top and 2 for bottum, same pn), i got those from chevy duty also. i got the 4 row radiator from napa, its made by modine and i think it was about 200 bucks. i'm not sure if you can use the small block fan shroud, i went with a big block fan shroud that i bought from pheonix and a flex fan w/spacer to center the fan in the shorter BB shroud
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-27-2004, 12:36 AM | #5 |
Dave, i lost the #'s and Pmed you for them again and got no response... with a 3 yr old running around i cant find alot of things. didnt want to bother you for them again.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
