Old 04-02-2002, 04:24 PM   #1
67c-20
Smile por-15
i just used the por-15 floorpan repair kit to do the driver side floor of my truck. it worked great. very tough stuff. i am pretty pleased with it. has anybody else used this product before? if so is it still holding up?
67 k-20 w/327 and a 3speed and 4.57 rear with 17 inch split rims and 9 inch wide rubber(is my current project)
73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires
54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc)
73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires. just put out 135 hp to the wheels on the dyno.
54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc). it is next in line for a rebuild
67c-20 is offline   Reply With Quote
Old 04-02-2002, 04:30 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Post
I used the gas tank treatment kit. I haven't had a problem with rust in the fuel filter since.
67
Ben
67Fleetsidedream is offline   Reply With Quote
Old 04-02-2002, 05:01 PM   #3
HuggerCST
HuggerCST's Avatar
Post
I used it on a battery tray. Acid leaked on it and stayed wet for weeks with no sign of corrosion or paint peeling.
'70 chevy swb cst
'70 chevy swb c-10 '70 chevy lwb for parts, '70 GMC lwb for parts, 2 '69 camaro RS's Ruston, Louisiana
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-02-2002, 05:12 PM   #4
67c-20
Post
i used it on my battery tray to it is good to know it can hold up. they make a repair kit for our crack prove steering wheel to. has anybody used it?
Old 04-02-2002, 11:27 PM   #5
BubbaGreen
Post
I just painted all the front suspension
components (new pieces) since I am going
thru the front end now...I havent got them
installed yet, but damn, it goes on nice,
looks great...time will tell how well it all
holds up...parts coated consist of:
Pitman arm
Idler arm
inner & outer tie rod ends (no, I didnt paint the threads)
upper & lower A-Arm shafts
upper ball joints (top half only)
Steering arm linkage (piece between rag-joint and steering column) it too looks great
POR-15 states it is UV sensitive and will need top coated if exposed to UV, ie, sunlight...I dont think these parts will see much sun, so doubt I top coat.
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 04-02-2002, 11:29 PM   #6
REPO1
Shortbox wanna-be.
REPO1's Avatar
Post
So it really works then? I plan on buying it and doing the underside of my cab, rockers, etc, to try and seal it up and keep it from rusting.
Reid
Sylvan Lake, Alberta, Canada
1970 Chevy C20 Custom Camper
#s matching 402BB Turbo 400 trans.
Air conditioning, power steering, manual brakes.
73,600 Original Miles!!
(Add on 2000 more from raod trip!)
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 04-03-2002, 12:41 AM   #7
71GMCstreet
Post
My 71 street is full of por-15. I've done the frame, inner panels (ALL of them), and motor.....yes motor. This stuff rocks!! it is probably THE most versitale product you can use to "clean-up" your projects. What is the best thing about this treatment is....very, very, very little prep work needed on old stuff. It is UV sensitive..., get the uv protectant stuff if exposed pieces are outside. It says "Paint-over-rust" but it really means "Paint-over-anything"
71GMCstreet is offline   Reply With Quote
Old 04-03-2002, 01:39 AM   #8
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
This is the first i've heard of this product, sounds just like what i need, where do I find it and how much does it cost???
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-03-2002, 02:10 AM   #9
67c-20
Post
go to por-15 .com it will have all you need. they have engine resto and many other products that will help with your resto.
Old 04-03-2002, 07:40 AM   #10
Ed ke6bnl
Lightbulb
Has anyone done a comparison between por 15 and Zero rust. I used Zero rust and it is cheaper but not sure if it is up to the raves I hear on por 15. Thanks Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
Sorry 50 F1 pu
Sorry 63 Ford Econoline pu
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 04-03-2002, 09:22 AM   #11
lux hauler
Psycho-billy Member
lux hauler's Avatar
Post
http://www.por15.com/
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 04-03-2002, 09:40 AM   #12
johnnyp
Keepin' It Stock
johnnyp's Avatar
Post
Here's a review of Zero Rust from a POR-15 user:
http://www.stovebolt.com/truck/techt...ust_review.htm
72 Sierra Grande - "Maych"
sierraG on some boards
If a man speaks in the middle of a forest and there is no woman around to hear him, is he still wrong?
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
Maych Home Page
72 Sierra Grande - Maych
johnnyp is offline   Reply With Quote
Old 04-03-2002, 12:08 PM   #13
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
Used the POR on my 56 steering wheel. It gets really hard and makes sanding difficult (understatement). I'm going to dremel the high spots down to 1/16" below the surface and apply body filler because it's easier to sand to the complex shape of the wheel.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 04-03-2002, 01:21 PM   #14
O'l Buck
O'l Buck's Avatar
Post
Awesome, I think i'll order some tomorrow!!!
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
Chad
Old 04-03-2002, 02:40 PM   #15
rus/68GMC
Post
For those who used it, how much did it take to paint a frame and did you sandblast the parts
68 GMC W/ PS, PB, AC. LWB GOING SHORT. GROUND UP RESTORATION
rus/68GMC is offline   Reply With Quote
Old 04-03-2002, 05:46 PM   #16
darrel_s
darrel_s's Avatar
Post
Sandblasted the whole frame. Took 3/4 of a quart to do two coats of por-15 on the frame. Took 1/4 to do all leaf springs , crossmembers, and gas tank. Looks great. Gonna wet sand and topcoat in a week or two.
http://www.forsakenproductions.com/1971_K5
darrel_s is offline   Reply With Quote
