Tie rod ends
I am replacing my front axle on my 70 K10 with one from a 75. On the 75 the tie rod end is a solid piece on one side and goes to an adjusting sleeve on the other. On the 70 it has an adjusting sleeve and you screw both tie rods to it. I want to use the tie rod end s from the 70 because I can get the adjusting sleeve powder coated. Does anyone know if this will work?
1970 k10 1971 C10 Gilbert Az |
![]() Join Date: Mar 2003
Yes it should work, both front ends should be dana 44s
Big Block Blazer
I would concur.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
Thanks guys I didnt want to spend the money on new ends and not have them fit.
