Old 04-26-2004, 06:52 PM   #1
68jimmy
68jimmy's Avatar
distributor as oil pump primer
I know that this has been asked before and I've seen the posting but I have been unable to locate it... Can someone please send me the/or a link that describes how to modify an old distributor so I can use it to pre-oil my new 350?
Thanks!
68jimmy is offline   Reply With Quote
Old 04-26-2004, 07:16 PM   #2
OhioDan
OhioDan's Avatar
I've got one, but no pics. Will try and get one later when the war dept. gets home, so I can use her camera. Easy to do. Don't remember seeing a post on this? Musta missed that one?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-26-2004, 07:50 PM   #3
Jimmy72custom
Jimmy72custom's Avatar
I have used a large screwdriver with the handle removed, and chucked into my drill. It is not hard to use if the engine is out on a stand. If the engine is in the truck it is hard to hold it centered. The old distributor is the best way to go.
Jimmy72custom is offline   Reply With Quote
Old 04-26-2004, 07:51 PM   #4
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Its easy, I made one from an old points distributor. All you do is remove the gear by removing the drive pin and puilling the gear off. I ground off the weights and rotor attaching points with a grinder. Grind it down as round as you can get it and small enough to get it to fit in a 1/2" drill or smaller if you only have a 3/8" drill.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 04-26-2004, 08:18 PM   #5
bigskiohio
just pull alll the guts out so so you can chuck it with a drill.
I did this probaly 20 years ago dont have it any more somebody thought it was junk and threw it away . so write on it or something, you could pull the shaft and have it turned down.
100th post woohoo!!!
bigskiohio is offline   Reply With Quote
Old 04-26-2004, 08:53 PM   #6
rage'nrat638
rage'nrat638's Avatar
HERE COMPLETE UNIT
rage'nrat638 is offline   Reply With Quote
Old 04-26-2004, 08:56 PM   #7
rage'nrat638
GEAR END....GRIND OFF THE GEAR.....SAND DOWN THE ALUM ROUND PART SO FIT'S INSIDE VERY EASY...
Old 04-26-2004, 09:00 PM   #8
rage'nrat638
I DRILLED A HOLE AND PUT A WASHER AND COTTER PIN TO HOLD'ER.....AND GRIND A HEX ON TOP TO CHUCK IT UP....
CLEAN TO $H!T OUT OF IT TO GET THE SHAVING'S OUT AND OFF...
Old 04-26-2004, 10:57 PM   #9
68jimmy
68jimmy's Avatar
Thanks for all the replies! I found an old distributor at the yard this past weekend. Once I grind off the weights how do I remove the plate that the points are attached to? Do I just pry it off with a screw driver?
Thanks again...
Old 04-26-2004, 11:25 PM   #10
Randy70C-10
Randy70C-10's Avatar
You have to cut the entire top section off the distributor. (Remove shaft first). I have one exactly like the pics that Mark posted, works great!
Randy70C-10 is offline   Reply With Quote
Old 04-26-2004, 11:31 PM   #11
68jimmy
68jimmy's Avatar
I'll get right on it! Thanks again for all the great information...
