Old 04-26-2004, 09:54 PM   #1
2birds40
esc
i did a search and see that i need to cut the black and green wires to disconnect the esc now do they get taped togher or does green go to green and black to black thanks
2birds40 is offline   Reply With Quote
Old 04-26-2004, 10:17 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
This is the photos that Mike used to have on 73-87.com that explains it. The article is still there on the site, but the photo link is dead.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-27-2004, 06:30 PM   #3
2birds40
hey thanks for the help got that all taken care of now i want to remove the harness for it but there are 2 wires running to a vacume siloniod of some sort on the pass. side fire wall what is it and do i need it i know i don't need the rest of the wiring but those two have me puzzeled by the way they are yellow and brown wires thanks
Old 04-27-2004, 11:27 PM   #4
Slonaker
Slonaker's Avatar
Sorry, I don't know anything about it. I just remembered Mike's pic, and thought it would help...
Slonaker
Stock '01 Silverado
Old 04-28-2004, 11:06 AM   #5
greg0380
It sounds like you are running an auto transmission. Those two wires go to a VAC TIP IN switch. There should be a vac line going to this switch connect to intake vacuum. If I remember right, it senses sudden changes in manifold vacuum and the switch would momentarily close. The ESC used this signal to control the spark on sudden vac changes. If you bypassed your ESC, then the switch does nothing. You will see TIP IN switch on the original emissions sticker (if you still have it). Mike Ervin explains the operation in his link. Good luck, Greg.
greg0380 is offline   Reply With Quote
Old 04-28-2004, 02:59 PM   #6
2birds40
hey thanks for the help guys i looked at the sticker it is the vac tip in so it will be gone by tonight
