04-27-2004, 08:38 AM | #1 |
ran out of money
best posi??
I currently have an open rear in the back of my truck but would like to go to a posi or maybe a locker. From what i have gathered i would not be able to drive on the street easly with the locker. so right now i am leaning twords a posi but i have cooked 3 posi's in about 2-3 years and 2 were straight from gm and one was a jasper rebuilt. so i am looking for somthing that can handle going to the track every weekend and doing a nice burnout and still hold up for a while. the main reason i was leaning twords a locker was because it can handle the abuse of the track.
has anyone used an Eaton posi? what do you think of it? Has anyone used an Auburn posi and what do you think of it? thanks a lot Rat
Modify everything, leave nothing alone!~ |
04-27-2004, 01:20 PM | #2 |
67-72 Addict!
I bought my Eaton frpm www.tomsdifferentials.com for $280 and have been very happy with it. I don't think Auburns are rebuildable.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-27-2004, 01:46 PM | #3 |
I granded an Pro-Auburn Posi, it was a nice and tight posi but it didn't last long..
Dana Power-Lok is what you want. It is as close to being locked without being locked. It is a rebuildable unit too. You can add or remove clutches to get a 'custom grip' if you like. They are not cheep. www.differentials.com I run them in front and back, great posi!! Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
04-27-2004, 02:53 PM | #4 |
ran out of money
anyone else?
Anyone running high HP engines with a posi? Thanks Rat
04-27-2004, 03:06 PM | #5 |
i have a moroso"brute strength" posi about$400 and has been in the truck for over 3years with no problems
04-27-2004, 03:56 PM | #6 |
eatons are rebuildable, where as auburns are not. if you can afford it, try going with an ARB Air Locker. great setup. a friend of mine had one in his mustang. 450 hp with about 475 ft/lbs of torque. withstood numerous burnouts. i recommend it
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
04-27-2004, 05:34 PM | #7 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
04-27-2004, 06:19 PM | #8 |
Rat those posis you cooked where they from 67-72 trucks? I was just wondering because i am in the same boat as you. I was told that the car posis are stronger than truck posis. Do you know if that is true? Manny
1968 C-10 Money PIT...... |
04-27-2004, 06:50 PM | #9 |
ran out of money
the posi's i cooked were out of a 99 chevy tahoe 2 door with a 350.. 2 of them and one in an 89 k-5 lifted with 35's
rat
04-27-2004, 06:55 PM | #10 |
The Moroso Brute Strength is a very good posi, its a tight packed posi also, more for racing than the street. I had one in my 66 Malibu 12 bolt and it did ok on the street though. You can definately tell its a posi to and how tight its set up. It has extra springs and clutch discs added and the case is very strong.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
04-27-2004, 07:02 PM | #11 |
ran out of money
were can i find out more information and place that sells a Moroso Brute Strength???
Thanks Rat
04-27-2004, 07:38 PM | #12 |
moroso; i got mine thru summit i think you'd have to call them i don't believe they have them in the catalogue
or just do a search for moroso's web site and they have a dealer find thing
04-27-2004, 07:47 PM | #13 |
Fabricate till you "puke"
Try summit racing, or Jegs on the Moroso unit....they might be a little stiff for street use tho(twice the spring preload as a stock type eaton). I run a rebuilt factory eaton in my 12 bolt, & it does ok for street use. The new eatons run carbon fiber discs, & can be had about $100-125 cheaper than the Moroso unit. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-27-2004, 09:55 PM | #14 |
Jegs ans Summit both carry them, they only list the 12 bolt car but they also carry the truck 12 bolt and car 10 bolts.
04-28-2004, 12:10 AM | #15 |
there is a product called powertrax that replaces the spider gears in a open diff. with a spring loaded deal that loocks both axles like a posi. you don`t even have to set anything up just follow the directions.the summit part number for a 12 bolt is PWT-92-0788-3005. it just says 12 bolt, doesn`t say car or truck but it`s a place to start.
Anthony |
04-28-2004, 02:49 PM | #16 |
ran out of money
i was thinking about the powertrax untill i talked to a few guys about it and they said it loads up and releases around turns and makes a loud noise each time it does that. for the price it seemed real nice but now i am leaning twords a posi that is more streetable. Right now i am kinda inbetween a moroso and a eaton. both seem nice and about the same price.
Thanks everyone Rat
04-28-2004, 03:01 PM | #17 |
if you go with a posi, i would get the moroso posi. 2 of my friends have them and they have been going for almost 10 years each and no problems and still very tight. i`m going to get one for my 70 when it`s time to build a rearend.
Anthony |
04-28-2004, 03:12 PM | #18 |
I've heard that the rear ends in 88-98 trucks are a real weak point. I know several people who have ruined them, and they seem a little hard to find in junkyards.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
04-28-2004, 03:49 PM | #19 |
I am running a 12 bolt eaton posi with steel clutches and so far, with over 400hp in the truck it has not even budged.
I think it has alot to do with the steel clutches and the amount of pre-load you put on the unit on installation. |
