04-27-2004, 04:02 PM | #1 |
Professional Grade
Gas lines
Hey all
I accidentally twisted my old fuel line on the truck and was forced to install a new one, unfortunately, to get it to fit, I have to loosen the fitting that goes into the bottom of the fuel pump, which caused it to leak something nasty. I got it tightend up, and put teflon tape on all the fittings. It doesn't drip anymore, but it is still always moist with gas underneith (leaking a little bit, but not too much at all) It doesn't matter if I rev the engine up to 5000 rpm, it doesn't spray out. Is this dangerous to run like this? I'm gonna go to Napa tonight to get some new intake gaskets and valve cover gaskets, should I get a new non-metal fuel line that runs from the pump to the carb?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-27-2004, 04:11 PM | #2 |
Garage Queen Material
sorry for the hijack.. but...
should i put some teflon tape on teh threads of my AN fittings? i got a 3/8" to -06AN fitting for the fuel pump and am wondering about that. |
04-28-2004, 01:14 PM | #3 |
As I was told in the Marine Corps. ANY leak concerning fuel is a bad thing. If it is enough to cause a part to be damp, vapors are also around. Vapors = BOOOMMM!!! Replace any part which is causing your problems.
ocbaud - some sealant/lubricant should be used on any pipe thread, such as the nipple which screws into the fuel pump body. The connections which use compression (the ones with 37 degree angle sealing surfaces) should NEVER have tape put on them. If you look for instalation instructions for the fittings you will find clarification on this. Last edited by NeCrOmAnCeR; 04-28-2004 at 01:17 PM. |
04-28-2004, 02:18 PM | #4 |
been here longer than Liz
I've always been told not to use any teflon tape for fuel fittings. I don't, and I've never had any leak...
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
04-28-2004, 06:17 PM | #5 |
Ob-Gyn Kenobi
AN type fittings are compression style...aka no tape
'85 GMC Shortbox... I used to have a firm handle on life....then it broke off. |
04-28-2004, 08:36 PM | #6 |
Professional Grade
I just got a new fuel pump from the wreckers along with a nice HD hitch (good for 12 000 lbs) for 20 bucks, woohoo
04-28-2004, 09:34 PM | #7 |
Here is a link from rusell pperformance. Pipe fittings get tape, and the compression fittings don't. Hope this helps clarify what I said earlier.
ocbaud was asking about a 3/8 X -6 AN fitting which screws into the fuel pump then to a hose. http://www.russellperformance.com/te...r_fittings.htm Last edited by NeCrOmAnCeR; 04-28-2004 at 09:37 PM. |
04-29-2004, 10:02 AM | #8 |
Check the flare on the fuel line. It should be a double-flare and seal with no leaks. I just had to fabricate a new fuel line for my GM 3.0L in the boat. No leaks! Leaks are especially dangerous in a boat.
Fuel Leaks in the Bilge = Explosion Of course, you'll always get the rare morons like the guy in Florida who pumped the hull full of gas through the rod holder a couple of weeks ago. Hit the starter and BOOM! Again, check the flare and the seat in the female brass fitting. Teflon tape isn't necessary since it's the flare and seat, not the threads, that provide the sealing surfaces. Good luck!
Semper Paratus |
04-29-2004, 02:31 PM | #9 |
Professional Grade
Well, the new fuel pump works real good! But that hitch reciever I bought doesn't fit Guess I gotta take it back and look for a new one that is off an actual pickup.
