Anybody know which frame holes I need to locate my transmission crossmember to? I have (will have) a 350/350 automatic. I'm guessing it's the ones right behind the front cab mounts, but want to be sure before I start tighting everything down. Thanks, Mike
'71 Cheyenne Super '80 Custom Deluxe '75 Blazer |
![]() Join Date: Dec 2000
I would like to know also, Im converting from 3spd std to automatic
69 C10 ![]() 65 Chevy II |
It's a catastrophic success.
![]() Join Date: Jan 2003
Everybody has their tricks, you might want to leave it loose until you have everything in place,(gives you moving around room)for aligning mounts and frame holes.
first set of holes in the frame behind the front cab mount.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Fabricate till you "puke"
I usually do like sneakysnake suggested, just leave it loose in the rails till you get the eng/trans planted. Depending on where the eng sits......factory V8 position, or I 6 position will make the difference in where the trans crossmember bolts down. Good luck with the project, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
