Old 04-28-2004, 12:57 AM   #1
72jimmy4x4
Body shims
Did the bodys of your jimmys come with body shims to line up the doors so they will close properley?
Thanks for any help
72jimmy4x4 is offline   Reply With Quote
Old 04-28-2004, 02:16 AM   #2
Jimmy72custom
Jimmy72custom's Avatar
Yes you can shim the body, but I would check your body mounts, door hinges, the pin is not to hard to replace. Then try to adjust the door and striker. Sometimes the problem is rotten pillar base and cab support, it will cause the Jimmy to sag. It is hard to tell what might be bad under the rocker panels.
Jimmy72custom is offline   Reply With Quote
Old 04-28-2004, 02:51 AM   #3
Alexis
Member since 2000
Alexis's Avatar
i don't think I've seen a door shimmed before, cowl and fender, yes. But like Jimmy said check the body for rust especially the under side.
Alexis is offline   Reply With Quote
Old 04-28-2004, 03:31 PM   #4
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
shims under the body or the shim-like things that are on the body in the door way.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 04-28-2004, 07:39 PM   #5
Tonyp
Tonyp's Avatar
what I did was use a flat washers and cut a slot from the outter edge to the center hole, that way all I needed to do was loosen up the bolt (not remove it) and slide the washer in. Some of the bolts are welded in and if you have carpet you would have to remove things to get them out...so try the "C" washer...
72 K/5
350/205
SOFT-TOP
DOUG THORLEY HEADERS
A/C
CUSTOM REAR BUMPER
http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG
Tonyp is offline   Reply With Quote
Old 04-28-2004, 10:20 PM   #6
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
You can buy the big flat washers with the cut out allready their but I dont know who sells them I need some for my jimmy Does anyone no where you can get them.
Gary 70 Jimmy is offline   Reply With Quote
Old 04-28-2004, 11:06 PM   #7
Alexis
Member since 2000
Alexis's Avatar
most auto parts store carry shim. Any local automotive paint shop should have them and different sizes in thickness.
Old 04-29-2004, 12:54 AM   #8
72jimmy4x4
Just got in the house from shimming body mounts 2 & 3 to get the doors to close properley. I had changed them all and fastened her all up to find the doors did not close to well. The old mounts were very bad some the bolts were just rattling around in there but the doors did close with out a hitch.
Old 05-01-2004, 08:22 AM   #9
Huck
Huck's Avatar
the GM book talks to shims to the mounts during the initial build process for door alignment so even with perfect inner rocker boxes, you may have to shim with new rubber mounts!!!
Huck is offline   Reply With Quote
Old 05-07-2004, 11:11 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I had a similar problem when I put new urethane mount's on my blazer and could not get the door's to shut a little shiming on th ebody mount behind the door's and now they close great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
