04-28-2004, 07:37 PM | #1 |
questions about new carpet and grille
i bought a new outer grille and a new carpet sat for my 69 and wondered a few things.On the grille,i had to remove the old braces on either end and reattach them.And that went ok.But when i went to try and do a test fit,it wouldnt fit.It would go around 1 headlight ok but not the other one.I cant remember how i took the other one off ,but do you have to loosen the front fender bolts on the rad support to get a little bit of leway to get the grille in?
and on the carpet....i took it out of the box just to take a look at it and noticed what im guessing is the grommet for the highbeam switch.Is there a hole already in the carpet?And how do you attach the grommet?
he who dies with the most toys wins... |
04-28-2004, 07:52 PM | #2 |
on the grill it is normal to have to loosen and spread the fenders apart otherwise it will go in so tight there is a good chance it will tear up the paint on the fenders (not to mention it goes in alot easier)
Shawn |
04-28-2004, 07:57 PM | #3 |
Shawn...ok,thanks....thats what i needed to know....love the grille BTW
04-28-2004, 08:18 PM | #4 |
for the carpet you'd have to position the carpet on the floor then cut a hole for the dimmer switch the grommet just slips into the hole
04-29-2004, 02:54 AM | #5 |
19mike69: Be double sure the carpet covers the 'COMPLETE" floorboard before you start cutting. I didn't double check mine last week and went ahead and cut for the tranny location and "THEN noticed it was too narrow on each side by the kickpanels! later Doug
04-29-2004, 07:14 AM | #6 |
67-72 Addict!
As 69short fleet said, check the fit from side to side and front to back- Twice!, before cutting. Mount your new sills, seat, belts and then cut for the dimmer. The grommet is a 2 piece that sandwhiches the carpet.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-29-2004, 07:32 AM | #7 |
A trick....
...to assist you in installing the carpet is to lay it out in the sun for a few hours prior to installation to "warm it up". This makes the carpet a bit more pliable, allows it to lay flatter and much easier to work with. Hope this helps.
7T1BURB |
04-29-2004, 03:43 PM | #8 |
ok,thanks for all the tips.....im guessing the carpet just lays in there right?GMC Pauls told me it just lays in there,no need for any adhesive
