Old 04-28-2004, 10:15 PM   #1
wxman1
Getting Hosed
OK here's the deal. I'm going nuts trying to find the correct
lower radiator hose. I have a 4 row radiator and the lower
snout turns upward instead of going straight out. So the hose has to curl around the edge of the frame member and then curl
back 140(?) degrees upward to the lower connection on the
water pump. However, the hose that AutoZone and Advance
Auto and Oreilly's wants to sell me doesn't have enough curl in it
and it flattens out against the edge of the frame member.
Anybody have this problem? Do you have a source for the
correct hose?
If you click on the link you can see and image of what the
problem is.
Jim
Mt Juliet
Lower Radiator Hose
wxman1 is offline   Reply With Quote
Old 04-28-2004, 10:24 PM   #2
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Well, you got me lookin' real close at my lower hose and I discovered its about to wear thru from rubbing on the frame. Prolly a good thing it was the suction side or it would have blown out by now.
Anyway, I have a heater in my lower hose, so its been cut apart to make room for the heater. You might have to go with a flex hose or just keep trying different parts stores. I know NAPA's hoses are made by Gates and they make top notch stuff. You might try that.
Most of the Autozone/Schucks/Pep Boys type parts stores sell the cheapest junkola they can find.
Cat Fuzz is offline   Reply With Quote
Old 04-28-2004, 10:32 PM   #3
crazy longhorn
Fabricate till you "puke"
Yep, I see the trouble. You have a 73 up water pump& a 67-72 rad & bottom hose. if you swap for the the 73 up truck lower hose, & swap the neck in the rad for a straight one, or swap the rad for the later & (73 up radiator), you should have a bolt up. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-29-2004, 11:37 AM   #4
wxman1
Thanks for the responses.
Crazy L:
The radiator is a brand new 4 row so I would not
want to change it out unless there was no other
choice. What about if I change the water pump to
a 67-72 style pump? Would that make things better?
Do the lower outlets on the 67-72 style pumps dump
out at a different angle?
Jim
Mt Juliet
Old 04-29-2004, 11:56 AM   #5
rodnok1
rodnok1's Avatar
I would try to look at a gates catalog with pics of all the hoses, probably can find online. I had a 75 pu that had that type hose on it. The other option may be to put a piece of solid pipe somewhere to lengthen the hose, think I have seen solid bends also.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-29-2004, 12:07 PM   #6
Mixup
I have the late model long water pump with a 4 row radiator and use the original lower hose with no problem. My bottom outlet on the radiator is straight.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 04-29-2004, 12:12 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally posted by wxman1
Crazy L:
Crazy L speaks from experience I'm sure
wxman1, if you do that then your accessory brackets and pulleys will most likely have to be changed to the correct 69-72 style as well.
Not to make fun of your situation but I see Bozall's theory of parts interchange, proving out once again. It's like Newton's Theory of Gravity, no sense fighting it. Crazy L knows what I mean, though he won't admit it :p
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-29-2004, 06:21 PM   #8
crazy longhorn
LMAO! CPNE, I do agree with Bozalls theory of parts interchange(I admit it ) parts interchange gets "goofy" for the next buyer of any project A very simple , & cheap solution to the head ache, would be to have a local rad shop swap the bottom neck on the radiator, then you can run the 73 up hose. Been there, done that! be Aware that not only is the bottom neck curved vs straight on the later rad, but the later rad also has a smaller dia neck(no problem). I walked into a local muffler shop, & had the later (small/straight neck) expanded , then took it home & soldered it in the radiator a good rad shop can also silver solder the small neck in place, & fill the gap. Just a little "fruit for thought" . Good luck,crazyL
Old 04-30-2004, 12:40 PM   #9
wxman1
Update:
Well I did finally find a lower hose that
would work...after some modification. It still
rubs against the frame...so I used a section
of another hose to shield it from any
chaffing.
Wow...when I bought this truck I never
thought I'd have to cure all the problems
caused by the redneck-engineering of one
of the previous owners!
I don't really want to leave the situation with
the radiator as is...I'd like to restore it to
"stock" look. It would help if someone has
a bone stock 69 with the 350 V-8...if they
could take a picture of the front/top of the
engine compartment so I could get an idea
of how much stuff has to be changed in
order to get back the "stock" look.
I think I have the correct radiator...the lower
snout turns up and that is what is shown
in the engineering diagrams in my
"Assembly Manual". However...my
alternator is on the passenger side. Also...
how do I know what the correct water pump
looks like?
Any help is appreciated!
Jim
Mt Juliet
Old 04-30-2004, 04:58 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
I think this truck has the origial pieces you need. click here
Old 05-01-2004, 01:11 AM   #11
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
My trucks not bone stock, but all the stuff is in the stock position. Not the best pic, but I can get a better one in the morning with my digi cam.
Old 05-01-2004, 09:36 AM   #12
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Update:
looks like?
Jim
Mt Juliet
Jim,
This isn't going to solve your problem completely, but it might help. I think the main difference with water pumps is long vs short. I ran into a similar problem, and in trying to 'fix' it ended up having to change from a long pump to a short pump just to get the right brackets for my alternator.
Here's a pic describing the differences.
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 05-01-2004, 11:00 AM   #13
wxman1
Well...I now have a short water pump. I am
also going to have to move the alternator
from the passenger side to the drivers side.
So now I have to locate a bracket for that.
Also...it looks like I'm going to have to find
another bracket for the p.s. pump. There's
a guy not far from here that has quite a few of
these old trucks...he can probably help me with
some of the hardware.
I was also able to search the forums for
pictures of different engine setups. That helped
a lot in determining what the correct brackets
were. Thanks to all who replied.
Jim
Mt Juliet
Old 05-01-2004, 11:43 AM   #14
jewels.
jewels.'s Avatar
Jim,
I'm so sorry I havent been reading the board lately. I have the answer you are looking for. About two weeks ago, I posted the same question about a lower radiator hose in a thread....
Here is the thread (clicky)
and i got a lot of good replies. People recommended the following hoses:
1. NAPA 7595
2. advanced auto lower hose #D71244
3. Goodyear, part # 60751 (For 72 Blazer)
4. CarQuest #20843
5. a 1980 305 engine
I purchased the Napa hose, which indeed DOES wrap around the frame, preventing a rub against the frame rail. Look at some of the pics on that thread link, and you will understand. Here is what the hose looks like after its installed (but I havent had a chance to install it yet).
I hope this helps you out!
ciao!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
