SLOW BUT SURE,BUT CLOSER
59 Cab with a 55-57 front clip?
Need to know if a 55-57 clip will fit a 59 cab. A neighbor has a rust free 59 he got at the Auto Fair and wants to go with a 55-57 front. Any tips or comments. Thanks Weasel
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
Yep, it'll fit but need to use the grill & hood from the 55-57 with them.
Happy to be here
![]() Join Date: Mar 2000
I have seen it done, and it looked cool. A few years ago I saw a 58-59 fleetside with a 55-57 front clip. It took a minute to register what he had done, but I liked it
Project56 on hold
i believe the radiator mount is different too.........
the cabs from 55-59 are pretty much the same. the 55-57 fronts can be interswapped no prob, other than the unique 57 grille. the 58-59 fenders are different, of course, because they started the quad headlight configuration, but i believe the 58-59 hood will still swap, though it drops in the center unlike the 55-57. also, the 57 hood has dual raised strips on it.
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold Last edited by ShamrockCustoms; 04-29-2004 at 07:15 PM. |
Cool thanks for the info, will pass it on.
are the hoods hinged in different places to??
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Project56 on hold
I'm pretty sure the hinges are mounted in same spot, been awhile since I have been under/in a 58-9 tho......
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold |
The 55 - 57 front clips will bolt straight up to the 58 - 59. The hood hinges are in the same spot, but I believe one of the holes are off, so you may need to drill a hole. I have a 56 Viking front clip on my 58. Its about 4 inches wider then a stock 1/2 ton, 3/4 ton, 1 ton truck front clip. And has its own unique grill. Not sure about the regular 55 - 57 front clip radiator mounts, but I know the bigger trucks are different. Because I had to change mine. Basically every single part off a 55 - 59 will fit from one to the other.
