38" tires/gear ratio
With 38" tall tires what gear ratio would work well??
Now I have 3.73 in 1/2 ton 72 blazer 4x4. Don't kown if I should jump into doing this swap?? Heres my deliema: Maybe getting 4.11 from 74 pick-up 4x4. The rear is 14 bolt and the front is DANA 60 flat top knuckle. Includes Drive lines, complete from hub to hub (front) and drum to drum (rear). He's calls it the heavy 3/4 ton. The big plus he said he install it all for $500.00! (axles & labor) Sorry if this seems to be a dumb A$$ question!! ![]()
72 blazer, 71 2wd short bed, 67 nova Too many damn toys!! |
get the new axles. more strength, and $500 is than buying 2 new sets of gears plus install.
dana 60 front axle wasnt introduced in GM trucks til '77. as far as i know, all dana 60's have flat top knuckles...at least all kingpin dana 60's.
it sounds like the front axle is actually a dana 44, which looks very similar to a dana 60. i'd be careful before i bought it. if you need to see pics of dana 44 vs dana 60, look in the link in my sig, and go to the photo album called "axles", you will find what you need there.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
user # 2756
![]() Join Date: Jun 2001
Yep I believe only dana44 are refered to as having flat tops and 1975 is in the range of years for them. Does it have 4 u-bolts holding the axle to both springs total or only 3 and 2 studs?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
The Blazer King
I would jump on that 3/4 ton deal. I am currently running 3:73's until I can afford a 4:56 swap. It is really underpowered. I would get a minimum 4:11 gear.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
I probably wrong on what I said about DANA 60.
1969 GMC: I looked at the pics and they don't look like those at all. They are flat top. JIMs70GMC: Yes there are 4 u-bolts holding the axles. Are you talking about the studs on the knuckle? If so there 3. Oh I forgot to mention the guy also said they are the big wheel bearing HUB/ALXES. Did they make 3/4 ton alxes that were DANA 44?? I wish my camera wasn't broken I would post some pics. Thanks alot. Anymore? Keep them coming!!
![]() Join Date: Feb 2001
Yep you'll need at least 4.11's. That sounds like the heavy D44 with the big hubs. It fools a lot of guys. Still a good set of axles.
Yeah, by looking at the front axle tub it look the same size of a 1/2 ton.
I thinking 4.11's will fine with a well built 350 or a 383 stoker. ![]()
user # 2756
On a dana60 there's one u-bolt and two studs holding the spring to the axle on the pass side.
I agree with Mudder67, nothing higher than 4.11's. My 72 has 4.11's with a mild built 350 and it has all the power I need. No problem turning 36" tires. It will probably hurt your mileage quite a bit. I get about 7 - 8 MPG, although, that has a lot to do with the 3 speed automatic. It Runs about 2800 RPM at 55.
The Heartbeat of America... Yesterdays Chevrolet |
Geared for Collision
depends on what you want to do with truck as far as gears, i currently have 4:56 gears with 33" wheels that sees some highway but i dont go over 65 , im changing to 35" tires so that should lower rpm a bit, i like low end power myself but if making a highway cruiser prob go with the 4:11 ratio sounds good.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
#13 |
Big Block Blazer
That link works well for figuring it out, thx BPB.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
