Old 04-29-2004, 12:08 AM   #1
soleeagle
soleeagle's Avatar
Question NP 203 to a NP 205
I am planning on taking out my NP203 that is in my '83 and replacing it with the NP205 that is in my '80. I am wondering what if any problems I might come into. Will this bolt directly to my tranny or are the shafts different? Both trucks have a TH350 in them. I am stripping the '80 and if I need to I will rebuild the tranny in the '80 to make it work but the one in the '83 is good and has no problems.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 04-29-2004, 12:28 AM   #2
The Dude
i am not positive, bu ti think that they mount differently to the tranny. so you could just pull out the transfer case and tranny together and swap them from the 83 to the 80 since they are the same tranny. and it would be easier that way, i found it easier to pull them together thn separate.
The Dude is offline   Reply With Quote
Old 04-29-2004, 12:36 AM   #3
1969 GMC
1969 GMC's Avatar
i am not sure about mounting pattern or spline count, but i do know that the NP203 and adaptor is prolly longer than the NP205 and adaptor, so your driveshafts will need to be changed.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-29-2004, 09:28 AM   #4
alf4444
alf4444's Avatar
its a direct bolt intranny and tcase wise but your dlines will have to be changed also if you have a complete donor vehicle your set
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 04-30-2004, 12:17 AM   #5
soleeagle
soleeagle's Avatar
Thanks for the info. I have a whole donor truck and I will probibly swap both tranny and transfer.
Chuck
Old 05-02-2004, 10:30 AM   #6
Truckstuff
Truckstuff's Avatar
NP 203 to NP 205
Hey. A stock 83 1/2 or 3/4T should have a long shaft Turbo 350 and NP208. Unless of course, it has be changed. The Turbo 350 for the NP203 and NP205 are the same (short shaft). But the Adapters between the transmission and transfer case are different.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 05-05-2004, 11:36 AM   #7
soleeagle
soleeagle's Avatar
Thanks. I have a chance to sell the other tranny but didnt want to till I found out if the one in my truck would bolt to the 205 or not. I will be sure to keep the adapter though.
Chuck
