Old 04-29-2004, 03:31 PM   #1
chicogixr
Heater fan still runs
I have a 79 K10 with AC and when the key is on, ya know before you start it, the fan runs. its not fast but it does. And yes all the switches are off. does anyone elses do that? its just someting else taking power away when the truck starts. not a big deal but why have a fan going if you dont need it.
Semper Fi
seafoam green 79 K10 stepside with a 6" lift, 33" baja claws, billet interior, autometer gauges, 350/t350
chicogixr is offline   Reply With Quote
Old 04-29-2004, 03:34 PM   #2
mhicks
mhicks's Avatar
fan
Yes, I have a '73 and it is on when the key is on. Is it supposed to do that? I don't know....
mhicks is offline   Reply With Quote
Old 04-29-2004, 03:41 PM   #3
Russell
Professional Grade
Russell's Avatar
Yeah, it is suppost to run all the time so long as the key is in the on position, engine running or not. It provides a supply of fresh air to the cab, thats why it eventually stops stinkin after breaking the wind, and also why you don't die when sitting at a red light for ten minutes due to carbon monoxide...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-29-2004, 05:14 PM   #4
76bonanza
76bonanza's Avatar
Hook it up to a toogle switch and you can cut it offin the summer so it does not blow more hot air in cab. As far as carbon monoxide my cab get plenty of fresh air through the numorous leaks in the cab.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
